Question about Locks & Locksmithing
My Go Travel lock is locked in the open position and the last known combination doesn't work. How do I reset it so it can lock?
    Top Expert:
  • Locks & Lock... Master
  • 1,533 Answers
Posted on Aug 01, 2019
SOURCE:
  • 38 Answers
SOURCE: How to reset EasyGo Travel Sentry 3-Dial Combo
well.maybe you should get a new lock because there is nothing to do with it
Posted on Sep 15, 2009
  • 150 Answers
SOURCE: my keys are locked in my box. i think the
http://www.masterlock.com/faq/lostcombo.shtml
Posted on Mar 13, 2010
  • 247 Answers
SOURCE: How do I reset the combination lock on my
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
Posted on Mar 19, 2010
SOURCE: century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
Posted on May 25, 2010
SOURCE: VIP Skybag lock combination forgotten.Bag
we took a bag skybag we got a lock free but the lock is not opening wat shal we do
Posted on Nov 20, 2010
Our suitcase is locked, and we forgot the combination. how can we reset the combination for our TSA approved luggage?
resetting the combination is only practical if the suitcase is open as the reset tab is located inside where it cannot be tampered with when locked.
if it is a set of dials lock a locksmith could help you.
regards,
Mar 25, 2018 | Luggage & Travel
How to set a combination on a Samsonite 3 dial combo lock
How to set a 3-dial luggage lock - YouTube
? 1:22
https://www.youtube.com/watch?v=TI4AgFhcnys
Sep 16, 2017 - Uploaded by Distant Lands Travel Store
http://www.distantlands.com How to set luggage locks. Simple and easy instructions on setting luggage locks.
3-Dial TSA Lock® & Cable - YouTube
? 1:21
https://www.youtube.com/watch?v=QlysHXuaftY
Jun 28, 2012 - Uploaded by Eagle Creek
it comes with a 50 inch cable. so that you can use this combination to go ahead. and secure different pieces of ...
How to Reset a Samsonite 3-Digit, Built-in Combination Lock ' USA ...
traveltips.usatoday.com > ... > Vacation Excursions > Things to Do on Vacation When purchased, the locks are set on a factory default combination that you can change as often as you wish. Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage. Locate the reset button, usually placed to the side of the combination dials. People also ask How do I reset my Samsonite luggage lock?
How do you open a combination lock without the combination?
How do I set the lock on my Samsonite suitcase?
How do you change the combination on a TSA lock?
Feedback
Lock Instructions - Samsonite
https://www.samsonite.ca/lock-instructions.html Luggage locks approved by the TSA have a universal master key that will open the locks (the keyhole you will see on your TSA lock, when you have not been provided a key ... Every TSA approved lock has an identifying mark that shows it may be opened by the master key. ... Have the lock set on your original combination.
Mar 17, 2018 | Samsonite Photography
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
STEP 2
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
Hartmann suitcase. How do I open Presto lock with 3-digit combination?
Look for my tip on opening luggage with combination locks in this listing.
Nov 27, 2015 | Luggage & Travel
I have a 3 digit 'Design Go' combination lock which we cannot remember the code (lock is in closed position) - how do we reset it so we can use it?
3 digits is only 999 combinations. You can dial each one and try it. Even if you are so slow that it takes 2 seconds per try, you'll go through all combinations in half an hour, and you'll likely find yours in ten minutes or so.
Oct 07, 2014 | Locks & Locksmithing
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Locks & Locksmithing Logo
77 people viewed this question
Top Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
