In numerous septic system, waste from toilets, bowls, showers, showers, floor drains and bowls courses through a labyrinth of funneling out to your septic tank or cesspit. The septic tank is typically framed of concrete or gum in more up to date plans with either apertures inside of the tank itself or downstream in the channel or field lines on the surge side of the septic system. Restrictions prevent the waste layer from leaving the tank and compacting the drain ranges. TG Wastewater
Ensure all your additional rough in plumbing is capped, and toilets or sinks that are not used for long periods of time , sometimes p traps may dry up allowing sewer gasses to enter the home so use them once in a while or fill with water once in a while ,same with floor drains. If that isn't it check that you have them installed.
If everything is going as it should and the sludge in your septic tank is decomposing properly you shouldn't need to empty the tank too often, but its a good idea to periodically pump out the tank to ensure against problems. You should be getting your tanked checked once a year at a minimum.
DONT TRY TO EMPTY THE TANK, RAISE THE FLOAT LEVEL. THIS STOPS THE PUMP FROM SUCKING AIR WITCH CAUSES THE PUMP TO LOSE PRIME, WOW THAT WAS A EASY ONE. ....NEXT
OH AND YOU MIGHT NEED A CHECK VALVE ??
JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA
