SOURCE: toro lx425 rider mower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
SOURCE: My Toro LX425 keeps on blowing 20 amp fuses when I
a fuse will blow if: a positive wire is being grounded to the frame or two much current is being passed thru it.
SOURCE: How do I get instructions on replacing both upper
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
SOURCE: lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
SOURCE: how do i adjust the
On the right side of your mower you should find a lever that allows you to adjust the cutting height of the deck up and down.
I hope this helps, if that is not sufficient just reply for some clarification and I will answer you question further.
Hi Mike McAlister, ...need more information from you. Please rephrase your question as it is vague/confusing.
When in reverse can not stop mower unless cutting off engine....brake has no effect on stopping or slowing mower down
