SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: setting the clock on the dvd recorder
Follow this sequence on the remote control:
Press FUNCTIONS/To Others/Setup/Others/Clock to access the clock setting mode. There, you will have the choice of Auto or Manual. Take your pick and away you go!
SOURCE: How do I change/set the clock setting on my car head unit? (actually a CDX-GT150)
press and hold the volume control and it should give you options on changing the clock.
Setting Time
1 While the clock time is displayed, press and hold
the CLK (clock) button for at least 3 seconds.
The time indication will begin to blink.
2 Press the ZERO button while the time indication
is blinking to set seconds to "0".
3 Press the HOUR button to adjust the hours while
the time indication is blinking.
4 Press the MIN button to adjust the minutes while
The time indication will stop blinking 5 seconds
after the last adjustment. The time will
automatically be set.
Good Luck
