Hi maisie dill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi maisie dill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Maisie, need a little more detail, you try to do what exactly and the machine is then doing what?
respond by selecting comment box below.Maisie, need a little more detail, you try to do what exactly and the machine is then doing what?
You can't post conmments that contain an email address.
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video): https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Is it plugged in?
