The power board controls the back lights. The issue appears to be related to that. However it could be the LED back lights are having an intermittent failure, if that is the case, replacing the power board wont help. Troubleshooting the LEDS when they are intermittent is a problem, you could replace the LED strips and see if that helps and if it does not then you replace the power board https://www.shopjimmy.com/vizio-0500-0605-1140-power-supply-for-d65-e0.htm
SOURCE: stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
SOURCE: Nintendo DS (F2 blown)
STOP!!!!!!!!!! Read This first!!!!!!!!!!!!
Do not buy 0.5Amp fuses.
please read the marking on the fuse before you order your part.
(Picture below: zoomed in snapshot of "F1" for a DS LITE
Notice the Letter "H" right there in the middle?)
The 0603 size is the appropriate size ... on that you are all correct.
IEC has standardized the markings on SMD fuses!!!!! They are as follows:
Amepere Marking
Rating
500mA F
750mA G
1A H
1.5A K
2A
N
2.5A
O
3A
P
3.5A
R
4A
S
5A
T
Cooper/Bussman, Littelfuse, Panasonic, Shurter, Vishay/Beyschlay have all standardized their markings on their SMD fuses (IEC compliant).
so if you order please make sure you get one from any of these manufacturers or that their SMD fuses are IEC compliant. Their markings will be the same for the rating of the SMD fuse you want to replace.
In summary, for a DS Lite with F1 and F2 with an "H" marking buy an
0603 size, 1amp, fast blow fuse
Lead free? or not? ... thats up to you.
Happy fixin :)
SOURCE: Samsung SyncMaster 940T. Suddenly went to black
The backlight is problem is caused by either a faulty inverter board or a faulty CCFL lamp.
Check out LCD Parts foe parts, service, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Testimonial: "Being pointed in the right direction is sometimes 90% of the solution!!! Many Thanks For The Compass!!"
SOURCE: Screen goes black when i quit any game, wont play dvd's
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO [email protected] I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i afrikaans BUT PLZZZ RATE ME Rusty
