SOURCE: Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
SOURCE: How to add Freon R407C to a ductless air conditioning unit
If you are not trained to at least charge a unit U will in the end do more harm than good get the proper service. what makes U think U need freon could just be dirty? Tom
SOURCE: How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
You need to take the cover off and you should see some aluminum fins like whats on the outside unit the blower will either blow across them or pull air accross them. Clean them with a wire brush and soapy water if you dont have coil cleaner which can be purchased at hardware stores
SOURCE: how to pump down a ductless air conditioner split unit to remove
if the unit contains R12 or R22 you are not permitted by law to do the work yoiurself .. you have to have a "certified" person to reclaim the freon ... you might be able to get away with removing R134A (check local law) if thats what it has ... there is a service port that you can hook gages/hoses/vacuum pump up to .. (if not, then one must be added, usually in the form of a saddle valve that penetrates a low side feed pipe ... you should vent it into an approved tank or bladder (like a big balloon) for disposal or reclamation .. there may be a community service in your area that comes out and reclaims freon from old refrigerators and such .. in my area there is a free service that will reclaim the refrigerant and take away the old equipment .. i think its free or low cost .. some people simply vent R134 to atmosphere but that is polluting and may violate some laws .. R134 was thought to pose little hazzard but that is being reconsidered now in many countries
you can become certified yourself by attending a class and taking an exam that shows you understand the dangers and are aware of the law ..
SOURCE: Where can I get an Installation Manuel on
You can go to goodmans website located at:
http://www.goodmanmfg.com/Home/tabid/36/Default.aspx
and search for your closest dealer/distributer and they can email you the manual. At this time, they don't have it on their website, not even under the dealer area (I am an authorized Goodman dealer) If they are unable to help you, send me an email ([email protected]) and I will get a copy for you and email it to you.
