o
ogbonwu peter Posted on Apr 04, 2019
I try with the 752059 clear error 092910,but it went away and come back. what can i do again ?
PANASONIC CS-CU E24PKR fault code H00
H00 No abnormality detected - Normal operation
You may have a problem with the outdoor controller, the indoor controller or both. Power outages can do some strange things to the electronics. Turn the A/C isolator off for five minutes and back on again to be sure the problem is still there. You could also try this:
• To clear memorized error (Protective operation) status
after repair:
1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
Code p0152
Rear Oxygen Sensor High (rich)
Before trying to fix it, first clear the error code and see if it comes back, it MIGHT be a historic code that came and went away in the past.
If to DOES come back, then it is a current code.
It COULD be a bad 02 sensor or even the wiring.
34helpful
8answers
Netflix error code 0013
Reinstalled Netflix app for android then error 0013 went away
1helpful
2answers
ERROR CODE LOC
I'm not sure what just happened here-I posted and my answer went away! Push and hold temp button for 3 seconds and LOC should clear-if you want to lock controls again repeat-cheers Denny
Dell Dimension 3100 Ithr error
updated your bios to the latest firmware. try to remove your HDD and check it once again. for further doubts post me again
ERROR CODE Er _4 appear on the LCD screen. What is the fault?
You got some electrical electrical problem. If you have tinkered some of the electrical components, back track what you did and find the mistake you made.
Clean the contact connectors and check if the are some oxidation on the metals. If there is, spray some contact cleaner and WD 40.
Try this to clear that error..........
Turn on your ignition, open the throttle full and turn off the ignition with the throttle still open the error code will be removed. Check it again to see the error, and it will be cleared away.
If there are still some probs, feel free to ask again.
Hope that helps you out!
4helpful
2answers
Error message ''Lens error'' on nikon coolpix digital camera
Try cleaning any grit out of the lens mechanism with compressed air and a little wiggling of the lens. If that doesn't do it, the camera needs servicing.
1helpful
2answers
The alarm light is on and it won't print
Check the back of the printer. Open up the back door. There is a barely visible 2nd door which you need to open. Check to see if there is a paper jam behind this 2nd door. Often this is the problem and clearing this back paper jam will clear the red alarm light.
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
