SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
SOURCE: changing the combination
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You
must have the factory combination in order to change the combination that was
added to the safe and the factory combination can not be erased if that is the
combination you are trying to erase.
All
you have to do is press program & type in the factory code 2 times &
that will erase the number you created.
Then
to add a new combination all you have to do is: press program followed by 5 new
numbers. Then to see if they new number works, just type in the new combination
& the green light should come on & you have 4 seconds to turn the handle
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button. The safe opened. The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe. Wrong! Do it my way should this problem happen to you.
SOURCE: I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
http://www.sentrysafe.com
the instructions are located link above.
mj
