SOURCE: Used Lanier LD435c needs to get reset to factory settings
enter the [user tools/counter] then before you press [system settings] hold it down pressed the [#] key and while the [#] key is pressed press the [system settings] key (on the touch screen or if dose not have touch screen than press ok) and the copier will return the settings to default. You can repeat the procedure for all settings.
SOURCE: how do i print envelopes on a Lanier LP331cn laser
You should see a bypass tray near the main paper tray. On laniers it is recommended you use the bypass tray for envelopes.
when you send a print job make sure to select the bypass paper tray option
