Microwave Ovens Logo
JenFrYrEyesOnly Posted on Apr 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore convection microwave burnt rice and bowl black sticky film noticed by fans area and inside looks discoloured smells burnt from rice and bowl that were black burnt....
Help needed to clean the fan area and the inside of this microwave...it still works but unplugged for several months...can someone help asap I can't handle toaster oven food any more...its a kenmore LG CONVENCTION OTR...MICROWAVE sitting on a buffet on wood blocks.....had it since 2005..its been great. Urgent help needed....to bring it to life....repair guys in Kitchener say buy a new one....this one is just needing cleaning....repair guys need to stop telling us to toss them in the garbage......also I by accident discovered if I use a bit of comet with water on a sponge and wipe the inside - of the microwave....its like new...its clean and no stains...I hope this is OK to do.....i just really need help getting inside the fan areas it's sticky gooey and is that because the fan vent on the microwave is not properly vented...or setup for counter use???? I wish I could safely clean myself tonight!!! Make some hot food! Thank you for your time and help every one....hope to hear from you soon :)
FastHarley
Level 3:
  • Master 761 Answers
  • Posted on Apr 04, 2019
FastHarley
Master
Level 3:
Answers
761
Questions
Helped
360213
Points
2528
Disconnect power and wipe down with vinegar and baking soda solution. Then plug in and heat the same solution for a minute or two. This should take that smell away.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 10, 2007
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Anonymous
  • 4 Answers
  • Posted on Dec 11, 2007
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Anonymous
  • Posted on Nov 09, 2008
SOURCE: Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Anonymous
  • Posted on Feb 12, 2009
built in 3/94 is it worth fixing how much for magetron
A Miller
  • 8404 Answers
  • Posted on Sep 09, 2009
SOURCE: microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
I hope this helps you.
Rag burnt, is it safe to use the micro? The rag burnt badly, there was smoke and a strong bad smell persists. Is it safe to keep on using the micro, what can be done about the smell?
Hello -
It is probably safe to use the microwave oven after removing the burned smell.
I found some methods for removing a burned smell from a microwave.
https://blog.bostonappliance.net/5-foolproof-ways-to-get-burnt-popcorn-smell-out-of-the-microwave/
(Quote)
1. Fill a bowl with 1/2 cup water and 1 tablespoon white vinegar.
  • Microwave it for 4-5 minutes and leave it with the door shut for 10-15 minutes.
  • Steam will loosen smell-causing detritus stuck to the walls. Vinegar absorbs odors, even stubborn ones like burnt popcorn smell.
  • After the waiting period, remove the bowl and wipe the inside of the microwave down with a paper towel
2. Not good enough? Okay - soak a sponge with vinegar.Place some baking soda on top and microwave the sponge for 25 seconds.
  • Wipe the inside of the microwave with the sponge.
  • Don't forget the glass tray and the microwave door.
3. If steps 1-2 don't remove all the grime, soak cotton balls with acetone-free nail polish remover and wipe down the inside of the microwave.
  • Even stubborn stains should come out.
  • Wipe down the inside with soap, then vinegar water, to remove the polish remover.
  • We recommend following through with step 4 to get rid of chemical smells.
4. Banish the remaining smells with the power of citrus.
  • Peel two oranges or slice a lemon in half.
  • Place the orange peels or lemon slices in a bowl of water (1-2 cups).
  • Microwave it for 4 minutes. Watch closely to ensure that the water stays in the bowl and the citrus peels do not burn.
  • If possible, leave the bowl in the microwave (with the door closed) for 12 hours.
  • Too time-consuming, or just not doable for you? That's okay too. Let the bowl sit in the closed microwave for half an hour then, if the burnt smell persists, continue to step 5.
5. Still bad odors in your microwave? Leave an open box of baking soda on your microwave tray overnight.
  • It will neurtalize the odor without adding to the smelly situation in any way.
  • You can also place coffee grounds from your morning coffee in a bowl in the microwave all day while you are at work.
  • If you don't mind coffee smell, you can microwave 2 tablespoons of coffee grounds in a half cup of water for 2-3 minutes to expedite the process.
(End quote)
Best wishes.
We recently had a rag burnt in the microwave. The smell is awful. Is it safe to keep on using the microwave?
Microwaving cloth is not a good idea. Rather than drying out the moisture (or for whatever reason it was put in the oven), microwaving it will just make the water really, really hot! You could easily burn yourself trying to handle the item. The heat could also damage the fabric itself or even ignite it....which it looks like happened.
The microwave oven should be safe to use but you need to remove the odor.
A couple of ways to try to get rid of the burnt odor:
Fill a microwavable bowl with 1/2 cup water and 1 tablespoon white vinegar.
  1. Microwave it for 4-5 minutes and leave it with the door shut for 10-15 minutes.
  2. Steam will loosen smell-causing detritus stuck to the walls. ...
  3. After the waiting period, remove the bowl and wipe the inside of the microwave down with a paper towel.
A different way is put two tablespoons of baking soda in a microwave safe bowl and add a cup of water on top of that. Then put the bowl in the microwave for three minutes. The baking soda will kill the funky smells and the water will start to steam clean the spots and stains.
Good luck with your troubleshooting.
Helpful?
1helpful
Microwave not working. Burnt smell
time for someone to unplug it and look inside, if something smells like it burnt do not plug in etc.
Common failure parts in most microwaves are:
Diode most use:
Magnetron which is connected to the inverter most use (circuit board)
AC filter cap which varies in shape some what but can be still tested with a ohm meter, also if really bad will be buldged out on sides or top.
No power
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
Microwave oven H-4020 BM...... How to clean inside????? I am unable to get the stains off and inside looks terrible.
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
When you press start I can hear the internal fan, but the inside table does not turn and there is no cooking taking place. What should I check first and what could be the problem?
This looks that the motor is not being functional, for that you have to look for the fuse if one. or else check the circuit if any wire is disconnected or burnt out accordingly you can decide what needs to be done.
3helpful
2answers
Need to clean air filter of burned popcorn smell
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
1helpful
2answers
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
