Question about Eliminator Electronics - Others
What is the proper orientation of a 3000 watt eliminator inverter?
  • Anonymous Apr 04, 2019
    The inverter will be on a vertical suface
4 Suggested Answers
SOURCE:
woodchuck789
  • 4070 Answers
SOURCE: How many watts does it take to run a GE 5cf
Your 3000 watts should be enough. An average freezer will need 800 or 900 watts.
Posted on Sep 20, 2009
  • 17 Answers
SOURCE: can't get my 84-2056-01 to work the inverter
This is over a year old, so presumably you solved your problem, but for reference for anyone else reading, the only connection between the inverter/charger and the remote panel is the RJ-11 phone type jack through which the remote panel also draws its power. Just make sure it is firmly seated (until it clicks) on both ends and that the wire is not crimped, cut, or chaffed in between. Otherwise, likely a defective remote panel.
Posted on Sep 27, 2010
SOURCE: Will a Whirlpool 21.7 cu
your refrigerator has a rated amperage that you need to check, the formula for wattage is volts(120)x amps(15)=watts(1800), your inverter must be rated for continuous duty
Posted on Dec 10, 2010
I have a 1000w eliminator inverter and its only putting out 100w. what do you think?
Hi....if you should be needing a 3000W inverter. No way you should use a 3000 watt inverter. Using an oversized inverter will needlessly draw power from the battery. Be aware that 100 watts of power used is 1 amp of battery power used. You have not said what size battery you have but most likely I am going to guess either a group 24 or 27, which means you only have 40-45 amps of battery power that you can use before you start damaging your battery.
Jan 10, 2018 | Inverter Electronics - Others
So back to my previous problem my inverter is a eliminator 3000 watt both fans are on along with the high pitch squeal if it's the over load what should I do to fix it
Remove the load and see if the noise, etc, disappears. If it does, then gradually apply loads. If the fault returns immediately, the inverter has an internal fault. If it fails as you apply loads, than you have exceeded the capacity of the inverter, so remove a load.
Dec 07, 2016 | Inverter Electronics - Others
What does opp stand for on a motor master 3000 watt inverter
Unit is shutdown with display showing "OPP"
Inverter is short circuit and has shut down.
Reset to normal operation by using manual switch
Nov 26, 2016 | Inverter Electronics - Others
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
Oct 22, 2016 | Eliminator Electronics - Others
My 3000 watt aims inverter/30amp charger seems to work but the charger will not charge/transfer when I turn on the generator. Charging indicator will not come on. It does transfer the generator power
dear see that :
1- the range of voltage which inverter work between it for example 180-260 v
2- most small generator voltage reach more than 260V so the inveter not work
3-check the frequency of genaratoer if it not fix the inverter will mot work
Oct 12, 2014 | Aims Power AIMS PWRIC300012W 3000 Watt |...
My 3000 watt inverter says "lup" on the display
This question is solved in detail on a different page here on Fixya by user Pierre Curtis in detail. It's very well written. Rather than repeat, just click this link:
http://www.fixya.com/support/t26322938-3000_watt_eliminator_olp_lup_codes_any 3000 watt eliminator with OLP and LUP CODES any Ideas
Nov 09, 2013 | Eliminator MotoMaster Mobile Power...
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Oct 22, 2017 | Duracell DS30R1i 3000 Watt Continuous...
I need to install my inverter 18 feet from my battery
a very thick one,,,like a baby battery lead on your car,,,its a very bad idear to have it so far away from the battery point, you would be far better off finding a closer place to put it as the volts drop off would have a big drop in out put on the inverter,,,also thats one big mother of a fridge to use 3000 watts????
you need a small power station to run it,,and if it do use 3000 watts your inverter is far to small to do the job, read the out put plate on the inverter,,it says 3000 watts max? not all the time,,,,thats about 2000 watts realy running contently and the whire to feed the inverter will need to carry about 30 amps so your car battery is say 90 amp hours plus the volts drop off, you would be lucky to have the inverter running for 3-4 hours before your battery go's is very flat on you!
Mar 28, 2010 | Inverter Aims Pure Sine Wave Power...
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
Electronics - Others Logo
27 people viewed this question
Top Eliminator Electronics - Others Experts
fisherman816
fisherman816
Mark Magill
Mark Magill
Tom Chichester
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
