I don’t recall this having a Bluetooth feature. If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Back rca may be convert to aux in setting menu
Unless it shown on the front panel, the answer is of course no.
SOURCE: where can I download owners manual for pioneer radio
www.pioneerelectronics.com go there and you can search your model number and download an owners manual through a .pdf file.
SOURCE: wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
SOURCE: setting my clock
I have deh 1450, turn ign on, radio off. On mine I pressed and held the top right button (audio) clock starts flashing. Set time using directional buttons (up, down, left, right) When finished I pressed the 'loud' button (bottom right of face plate to end
SOURCE: CDJ-1000 CD Player: SIR I HAVE 100S POINEER WHN I RUN CD I FACE ERROR ...
hi there,
you need to clean compartment of your cdj. Pls make sure if you can do it yourself then do it yourself or take it to an expert.
djajay
SOURCE: want to connect a android to the radio without
There is a cable/jumper to do such a thing and you can get the cable/jumper either through someone on ebay or try one of the local audio connection stores.
