Switch the power off and release the outlet from the wall box and carefully draw it out to the extent of the wires and check it is wired correctly then turn on the power and again very carefully and using your trusty multimeter check that current is reaching the terminals behind the power outlet unit.
If power is present and the wiring is correct, replace the power outlet unit, though take a close look and check for the presence of a fuse in the unit before you spend money.
Try reversing the wires.
SOURCE: Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
SOURCE: Problems with a GFCI outlet (no voltage). GFCI
if your room is powered by one breaker you need only one gfci and it has to be hooked up correctly to protect the other outlets a new gfci will have a tape tag over the out side usually the top set of nuts the water in the panel is a major fire hazard i would fix this problem first your feed to the gfci may have shorted out in the wall between the breaker and the gfci if it is wired separate from the other gfci in that room one thing you can do to save calling an electrician is go to lows home depot or any electrical store and purchase a plug in tester they are inexpensive and easy to use it will tell you if wires are hooked up correctly backwards or if you have a short somewhere in the line this is the same little gadget that an electrical inspector uses to make sure new homes are wired correctly an outlet will still work even if some wires are incorrect in the circuit the outlet tester confirms all is good and safe
Hi Ruby Tatum, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is your exact question, breaker of recpracle?
