Trying to remove it
Go to google Image ask for the schematics.
Canon Imagerunner2525
RTM yet, read the manual>
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/multifunction-copiers/imagerunner-2525
Testimonial: "nothing mentioned of location of HDD in manual"
not the users manual, its called a sevice manual. talk to them get the manual.
you'd need that to say if you found the HDD
and it is bad and need to replace it.
all these steps to do that are unique to this printer.
why not ask on their forum,? the makers.
or there support community as the call it now.
SOURCE: Describe how to remove hard drive from canon
what you will have to do is remove the back cover.
then you will need to remove the thin metal cover laying flat cover on the back half of the copier just under the doc feeder. should be 3 screws.
then there is a metal box that holds the main controller on the right. if you open that you will see the IDE cable which will run up and out of that box and will run up under a thin metal plate that should be held in by 2 screws. if you remove those screws you should be able to see the hd .
if you can't get it out and or find it please call me it might be easier to explain. over the phone.
C & S Canon Copier Repair
(858)414-8475
Testimonial: "I was able to find the HD and now I am going to replace it. Thank you very much for the answer it was very helpfull. I even call the tech and he helped me out over the phone. FixYa I think you are doing a great service!!!!!"
