SOURCE: FORGOT SECURITY CODE TO MOTOROLA I776W CAN SOMEONE PLEASE HELP!!!
call your service provider on a different phone and they will give you the manufacturers number then tell the manufacturer your problem and the will help for a master reset
SOURCE: i cant remember the security code to clear my
the default code normally is 12345 . If you changed it then you have to remember other wise get code reset from the gallery
Testimonial: "very good thanks very much i worked :))))"
SOURCE: my yahoo email account password
Unfortunately all I can do to help is offer a little advice. The best thing to do will be to try and go through their self help until you get to an area that can guide you to someone you can speak with. Unfortunately however you will probably need to make a new account to log in with so someone can speak to you. You could delete that account afterwards, but it would be more work overall. Yahoo also has an online help support chat which should best help you. Give the link at the bottom a whirl before anything. You may have to log on at another time however when their chat is available.
http://help.yahoo.com/l/us/yahoo/edit/cctop/forms_index.html?last_url=http://help.yahoo.com/l/us/yahoo/edit/index.html
The prompt you are receiving is called "Second sign-in verification," and it is designed to protect your account from unauthorized access.
There are several ways to confirm your identity:
Send a code to mobile phone or non-Yahoo! alternate email address:
Note: At this time Yahoo! alternate email cannot be used to confirm your identity. If your alternate email address is a Yahoo! email, please use your mobile number or security question.
Verify your security question:
If you do not have a non-Yahoo! alternate email address, valid mobile number, or cannot verify your security question, you may need to contact Yahoo! to confirm your identity. Note: When filling out the form, please select Yahoo! Account under "Product."
How does Yahoo! use the telephone number?
We and TeleSign Corporation, our partner who helps provide this service, shall use the phone number to send a validation code. We also track each number to make sure it isn't used too many times. We will not use the number to send you promotional or other unwanted messages, unless you've given us permission elsewhere. We do not share the number with any other company or organization except TeleSign Corporation, which retains the number no longer than 90 days. Learn more about Yahoo!'s privacy practices.
By email
