Question about Refrigerators
I have a hisense fridge that shows e3 in the freezer area. It has ice build uo which blocks airway to the fridge up, and so the fridge is not working . Technician's advised that the temperature freezer sensor is not working and needs replacement.I ordered the temperature fuse, the defrost stick and the temperature sensor from Hisense, according to the spec of my fridge replaced them but e3 message is still there. What could be the issue. Is there a way of resetting the fridge?
    New Friend:
  • 9 Answers
On a lot of fridges the error code relating to not defrosting will remain until it runs its next defrost cycle, then it will clear the error.
This can take a few days to happen.
Posted on Apr 03, 2019
SOURCE:
duby1990
  • 370 Answers
SOURCE: ice/frost build up inside the freezer
You have a defrost problem. The coils freeze up behind the freezer wall and the air does not flow properly. Replace the heater, defrost timer, and thermostat. get me the model number and i will give you the part numbers so you can order the parts.
Posted on Nov 19, 2008
SOURCE: Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
Posted on May 07, 2009
  • 19 Answers
SOURCE: Need photo of freezer defrost sensor, switch or thermostat
Before replacing all of the components mentioned above, locate your defrost heater and check for continuity with an ohm meter,this will ensure no breaks in heater coil
Posted on Jun 29, 2009
woodchuck789
  • 4070 Answers
SOURCE: Ice build-up in lower freezer. We replaces the
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check , defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control. Part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MSD2756GEW&productCategoryId=0165000&brandId=3048&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00002&componentDescription=CONTROLS&documentId=M0404275&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 16, 2009
ginko
  • 19396 Answers
SOURCE: The Miele Fridge Freezer KFN8462S
Hi.
F2 indicates that there is a defrost problem. For this reason, if you turn off and defrost the fridge manually, the unit will work for a while after doing defrost.
You said that you replaced temperature sensor. What is called temperature sensor is different from the defrost thermostat, which is one of the parts involved in the fault.
If there is no defrost cycle, or if defrost is insufficient, problem is usually the defrost thermostat. The thermostat is located behind the freezer section rear wall, where the evaporator resides. To access it you need to remove frozen food and undo screws holding the back panel. The thermostat is a metal cylinder shaped object connected to two wires and clipped to the evaporator. The thermostat can be tested using a multimeter set on impedance. If reading impedance at room temp. on the thermostat contacts is infinity (circuit open),then the thermostat must be replaced. In the same way is tested the defrost heater. Check also that evaporator fan is starting.
If parts in the evaporator section are working, then the problem can be the defrost timer, which starts the defrost once every 8 hours.
Here how thermostat looks like. In same page read also the repair instructions from other users.
Regards.
Ginko.
Posted on Jan 25, 2011
My fridge temprature constantly keeps going up even after turning on the supper.
Something new is blocking the airway from the freezer to the fridge. Check the freezer, look for vents that have been blocked. If it has been blocked too long, ice can build up in passageways in the freezer that are hard to get to. Maybe the fan got jammed, you should hear it when the freezer door is closed. It usually stops when the freezer door is open, but if you push the switch it should run.
Nov 21, 2013 | Refrigerators
My refrigerator does not work but freezer does work
Check to see if there is ice build up in the connection from the freezer to the fridge. The fridge part gets the cold air from the freezer. If area is blocked, cold air is not coming down.
You will have to defrost the fridge to remove the blockage. Place all the contents into another refrigerator. Unplug the fridge and allow it to defrost for 48 hrs. Make sure you have towels to collect the moisture from the freezer.
Feb 28, 2011 | GE Refrigerators
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Fridge not cold - freezer fine
ice buildup will most likely block the air flow.
if so the air will not be able to enter fridge section. Check air vent in fridge side if you can hear the fan and get no air flow then its blocked - common defrost thermostat failure.
to temporarily clear the problem just use a hair dryer on the ice build up area
Aug 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
My freezer is real cold with frost build up but my fridge will not get cold
unthaw the freezer you have ice blocking the cool air from getting to the fridge area
Jun 21, 2009 | Whirlpool Gold GB2SHDXPS Stainless Steel
Air is not getting to the fridge from the freezer. Defrosting it now, but this is the second time in a week.
your drain hose in the freezer must be blocked with ice and its freezing the airway to the fridge ,you have to let it defrost for at least a day or use a hairblower on low and defrost the freezer
Jul 07, 2008 | Frigidaire Refrigerators
WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
If the frost is on the back wall of the freezer then you most likely have a defrost problem or a bad evaporator fan motor.
Jan 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
415 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
