Question about Electronics - Others
Roland rd 800 USB Memory Not Ready Usb is flashing
SOURCE:
SOURCE: Rd 2030 Usb Driversusb Downloads said name
rconnect_lg_rd_2030_com.zip
type this in google search
Posted on Nov 10, 2008
haayz
  • 197 Answers
SOURCE: usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Posted on Jun 02, 2009
  • 5 Answers
SOURCE: USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
Posted on Jun 18, 2009
  • 1140 Answers
SOURCE: Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Posted on Jul 17, 2009
  • 5603 Answers
SOURCE: Sir i have purchased Roland
Read pages starting with 49 in your user's manual.
You MUST format the USB flash in the GW-8 before it can be used. Formating in a computer MAY b e inadequate as sometimes the formats have special quirks.
Also pay attention to the MAXIMUM file name length... It is 16 characters MAX !!!!
Posted on Feb 16, 2011
How can i fix my micro sd parameter error
YES , 1 st use memory card reader and connect to your PC 2 nd right click on icon and format it , in format option use tick both the option 3 rd scan and walla its done
or else
go to service center and say your problem and ask for replacement
bye
Sep 01, 2011 | SanDisk 2GB microSD Memory Card
How do i format the usb stick so i can use it?
With the computer on and you logged in.
  • Plug in the flash drive and open Computer/My Computer
  • The flash drive should appear
  • Right Click it and select format. Leave the defaults and give it a volume name if you want. After it formats it's ready to go.
Comment back if you need more help.
Aug 30, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
My memory card is showing shortcuts inside.. all folder changed to shortcuts.. n i m unable to open this.. pls suggest me answer
This is one VIRUS. Please Scan that sandisk with any antivirus. just you can use Kaspersky.
The manual procedure to see all the fiels is:
1. Connect the USB drive
2. go to command prompt. Run-> cmd
3. goto sandisk drive
by default c:\> prompt appears. type the drive letter with colon.
c:\> E: (if E drive assigned to your sandisk)
you can see in mycomputer: drive letter may be e: or f:
4.After getting that drive as prompt. like e:\>
Then type these commands.
attrib -s -r -h *.* /s
attrib -s -r -h desktop.ini /s
attrib -s -r -h autorun.inf /s
del desktop.ini /s
del autorun.inf /s
rd recycled /s
rd recycler /s
rd $recycled /s
5. Then goto My computer. you will find the folders and shortcuts also
please remove the SHOTCUTS only...
This will helps you .,
Jun 17, 2011 | SanDisk 1GB microSD Memory Card
Sir i have purchased Roland gw-8 keyboard in the usb port when i put any flash drive it power is shown but it doen't read and it gives message usb memory not ready sir please solve my problem?
Feb 16, 2011 | Roland GW8 Keyboard Arranger
I have a usb all in one memory card reader how do i use it
Its a plug and play hardware that you can insert in usb socket of your computer...
wait for your computer to read it and prompted you "your hardware is installed and ready to use" seen on the lower right portion of your monitor.
Insert the memory card from your camera or phone on the usb all in one memory card.
You can start browsing the files from your memory cards.
Hope it help..
Much appreciated if you could rate this help.. thanks
May 21, 2010 | Electronics - Others
Jul 16, 2009 | Music
Electronics - Others Logo
44 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
