Computers & Internet Logo
R
Raheem Muhammed Posted on Apr 03, 2019
How to block port scans on Zyxel C1100z router? Every time I configure the IPv4 Firewall it reverts back to default settings.
5 Related Answers
bpcs
Jim Bruner
  • 112 Answers
  • Posted on Dec 29, 2007
SOURCE: trying to configure zyxel nbg334w router
If the router will not connect to the internet, you will need to create the PPPOE internet connection with the username and password that your ISP provided. BPCS
Anonymous
  • Posted on Jul 01, 2009
SOURCE: can anyone help me set up a dmz on this router(zyxel p 334)
Do you have a static IP to portforward with? i would not recommend DMZ because most routers lie - they still use a firewall even with DMZ.
Anonymous
  • 70 Answers
  • Posted on Jul 26, 2009
SOURCE: The Zyxel router will allow me to 'Ping' from the
You should reset the router. or change setting by access the gateway
Anonymous
  • 148 Answers
  • Posted on Aug 12, 2009
SOURCE: Problem with firewall rules and access from WAN
  • call your router support to disable first the firewall on the WAN setup
  • the do port forwarding
Anonymous
  • 17 Answers
  • Posted on May 02, 2010
SOURCE: Listen Port of TCP: 2869 (Blocked by
try to disable ur firewall setting, enable nat, and rip
try set port forwarding to port 65535, dont forget to set bitcomet port 65535 too
How to change Pass word
Hello it depends on your router.
Read more here:
http://www.zyxel.com/support/knowledge_base/kb_detail_1850.shtml
http://www.default-password.info/zyxel/
Here is a video that shows how:
http://www.youtube.com/watch?v=19WI2dl-QU4
You might have to reset router to access the page.
Press the reset button at the back of your router for 30 sec.
and release.Wait for it to boot up again.
Now the router is set to factory settings.
Connect your lan cable to the router to one of the ports 1 to 4
and to your computer
To configure your router's wireless network open Internet Explorer and navigate to the router's configuration page by typing 192.168.1.1 into the address bar. When the page loads you will be prompted for your Router configuration password. By default this is 1234.
(You have to find the username and password first)
Try to download a manual for the router:
http://www.zyxel.com/support/download_library.shtml
Please select your model and number.
Do not use a easy password so others can use your internet connection.
Good luck
2answers
I want to assign a DMZ' to my router to help my ps3 firewall change from restrictive.... how do i do this??
If you have servers on your LAN, configure an SUA server set to have them visible to the outside. From the NAT - Mode screen click Edit Details and fill in the fields as show
do this to setup a DMZ
Hi there! i have a zyxel ph660-f1z and since it doesnt suport dmz i get nat type moderate on my ps3 so it gives a lot of trouble.... i have tried port fordwarding,upnp,default server but nothing seems to...
Sometimes not just the dmz or port configurations cause your nat settings to be other than open, you may not have good internet connection, the better it is the more you will open. Most routers are open by default, and those others need to be forwarded(like you wrote) with the upnp open and specific ports for xbox/ps3 servers opened. You seem to know a little already, maybe time to get a new router?,I recently upgraded myself due to problems with configuration.
Can't access configuration setup
There was a small reset switch on your router, press the reset button for 5 second to reset the setting into default factory settings. Like in your case it is possible that the router need to reset for the first time.
Kindly let me know for further more assistance.
Thank you for using fixya.
micro-
2answers
No matter what i do, ports will not forward
you have to TURN ON both FIREWALL AND NAT, and then configure the nat forwarding + firewall rule and then it will work
it's a known bug @ zy boxes
1helpful
Still cant solve it.
The default address to get to the web interface is 192.168.1.1
The default password is 1234 (No username required)
If that doesn't work, you can restore it to the factory default by pressing the reset button on the back and holding it in for 10 seconds. Be aware that doing this will erase all existing configuration information.
Here's a link to the quick start guide:
ftp://ftp.zyxel.com/P-320W/quick_start_guide/P-320W_1.pdf
Here's a link to the Users Guide:
ftp://ftp.zyxel.com/P-320W/user_guide/P-320W_1.pdf
No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
7 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
8 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
9.Then u can configure the ip address
Regards,
Ayyasam
1helpful
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) multiplex..llc virtual...
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Unable to log into router to open ports
To log in to the router in order for you to do a port forwarding you can follow the steps from this link, but if the default username and password didn't work reset the router so it will be back to its default settings http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-T1v2/Age_of_Empires_III.htm
Port forwarding
well to start, your connection would possibly be ADSL and your zyxel is set to provide DHCP address on your network, so its router capabilities could be turned on.
if this is true, you may need to rework the connection settings.
here's a recommendation:
1.set your modem to bridge mode (bridge only)
2.this will then be allowing your linksys to manage your DSL connection through PPPoE
3.after so, your linksys router should get a public IP address for an internet IP when you go to status tab (not an IP address starting with 192.168.1.xx)
after so, you may reconfigure your port-forwarding.
the reason why you will need to set your modem to "bridged" only is that if it is not, your zyxel's firewall is also turned on, provided that the linksys' firewall is always on. so even if you define which port will be opened on the router, it will still be blocked by the modem's firewall.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
