Possible low voltage from transformer or board bad
SOURCE: Low voltage light flashing
I haven't worked on one of them in years but I looked at a breakdown and the parts are as I remember. Go to Milwaukeetool.com and under parts/service type in your model number and view the wiring diagram for an operational check procedure. I would first look at the cord and is the base sitting on 1/2 or greater plate steel. If rusted or painted you will loose some of the holding force. Also I don't know what motor you have but some of the larger units require a lot of amps to operate and it is possible that even though you plugged it in direct to wall the circuit wasn't sufficient to operate both units. Last resort call the tech dept. at Milwaukee and see if they have any ideas. That panel is a component part as you know and there were no replacement parts for it. Hope this helps if not let me know and I will do some more checking
SOURCE: I have a goodman furnace and ac unit the fan and
Look at the contactor on the condensing unit, remove the low voltage wires to the contactor and turn on the system. If the low voltage fuse doesn't blow, replace the contactor.
SOURCE: Transformer blew on Hk395 speaker sysytem
I think I remember it being in the 12-24VAC range. If you are still interested I will open mine up and measure it.
SOURCE: 2002 kia sportage airbag light flashing 1 -3 code,
first thing to check, how is your battery? Are the battery posts clean? next check your fuses. replace as needed. sometimes if an aftermarket stereo has been added, the wront power cord may have been splice. need to get the exact coce and find out what it means. i have never heard of a 1-3 code, usualy there are in the form of T0222 or T444 or something close to that.
hope this helps a bit, the actual error code would help quite a bit
