My friend accidentally deleted files and now does not know how to recover them. What programs are there to help deal with this problem?
Backup your computer to the last time you updated it. You can do this by searching "restore" in windows or "backup" . After finding that, simply open it and follow the prompts provided to backup your computer to last update or major event in your computer.
-Also check %temp files, since sometimes the deleted programs have a copy of it transitioned into there like a "after image".
I hope this helps!
I hope this helps!
I hope this helps!
I hope this helps!
Check the garbage bin on computer. If he's gone past that.. whoops. You might need someone to access your hard drive
An easy to use program called Recuva. I've used this with some success in the past. Understand that while you may be able to get a large percentage back (if the deletion was relatively recent) some will most likely be corrupt in some fashion. Good luck!
SOURCE: recover deleted files from Cruzer?
Since you are using Macbook, you can go to this program USB Flash Drive Recovery for Mac for help.
If you are running a computer with Windows, go to Data Recovery for Windows. It should help you out.
Note: before recovery, DO NOT save more files to the USB drive.
SOURCE: I need to recover deleted pics
I have had success with this... Download Asoftech Photo Recovery program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
SOURCE: need to recover deleted photos
You can connect camera's memory card to computer, then download this picture recovery program which is outstanding among all picture recovery software.
http://www.001-software.com/picture-recovery/
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this camera photo recovery software
Install and open the photo recovery software, select the memory card, and click 'Start' button.
SOURCE: how to recover deleted files in nokia c5
Do not worry, it is possible to recover deleted files from Nokia C5. You may follow this step by step guide which helped me before
mobile phone file recovery guide
It's very easy to follow and works well for me. So have a try and get back deleted files.
