Question about Janome Sewing Machines
I have a Janome Skyline 9 sewing machine. The flywheel will not move and I get an error message that begins " Warning! Is something stuck in the machine? Is the cloth too thick?"
I had just changed out the bobbin during an embroidery project when this happened. I have turned the machine off multiple times (even overnight) and the problem has not resolved.
    Sergeant:
  • 210 Answers
Try taking the bobbin out and see if the machine will turn by hand movements using the flywheel or running the motor, you will feel and resistance if there is any but do not force the machine! if the machine turns without getting stuck then try a different bobbin as this might indicate a problem with the bobbin. I am also assuming you have placed the bobbin facing the correct way meaning the thread which is an easy mistake to make. Next, try eliminating different parts of the machine like turning it on different settings or without a needle, open the front part of the machine where you would normally replace the light bulb and watch as you hand turn the machine for any knocks or places of resistance, also unscrew the very backplate at the flywheel as the machine is usually connected by a rubber belt going from the motor to the machine and check that it is not caught up or broken. On older machines that did not have an onboard computer made it more easy to solve problems because if there is a problem the machine wouldn't just shut down, So elimination should solve the issues.
Posted on Apr 03, 2019
SOURCE:
smilemaker
  • 790 Answers
SOURCE: Janome 10000
Hello sir,
Have a look at this .. this may help you ... CLICK HERE
Posted on Mar 11, 2008
bargainbox
  • 1388 Answers
SOURCE: Janome 10001
This is a protection mechanism of the machine when it believes there is too much strain on the motor.
Check the hook race/bobbin area...for lint or thread jam....also check the couterweighted cam that drives the needle up & down, as ofter thread will catch and be wound around the shaft near the take up lever.....open the door on the Left (Face Plate) and where the shaft comes through the body is where to look, move the handwheel slowly and watch for threads....remove them gently by unwinding, be patient as they may be well jammed.........DO NOT pull and break them !!
If you are convinced there is nothing jammed & if all appears clear, there are 2 possible scenarios, and I am afraid you are not likely to be too pleased by either of them.........please don't shoot the messenger.
The DC motor is failing, or
The "A" board has problems.
Janome have a 5 year warantee on the Circuit board and will replace it if it fails within this period.
This is a complex and valuable machine and may need the services of a well qualified Janome Trained Service Technician, not just any old hack repairman.
Protect your investment.
Best Wishes and hopes it's just the thread jam.
Posted on Mar 14, 2008
I've been having the same problem with the error message. I finally took my machine to the shop Monday. They called me a couple hours later and said I needed a new motor. I picked it up this afternoon. I've only sewn on it a few minutes, but no messages. That hasn't happened in a long time. I'll test it some more tonight when I do some embroidery. It does sound smoother. We'll see!
Joyce1492
Posted on May 17, 2008
Alleluia
  • 69 Answers
SOURCE: Dear Sir,
There is a chat room for Janome sewing machines at following link:
http://sewing.patternreview.com/SewingMachine/Janome/
Hope this helps
Alleluia
Posted on Nov 14, 2008
  • 30 Answers
SOURCE: my material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Posted on Oct 28, 2009
How to fix the timing on a janome skyline s7
Search for:
sewing machine timing
lots of videos, web sites
Jun 19, 2018 | Janome Sewing Machines
Janome 10000
so..it only happens in your house? anything odd about the power coming to your machine? have you tried it on another outlet? that might explain why the dealer can't see the problem...
Mar 11, 2008 | Janome Memory Craft 10000
Will a 7 mm high shank adaptor work for Janome skyline s5?
Perhaps this will help:
https://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx?sort.ss_cat_sort=desc&index=1
If your machine has a presser foot sensor, it's likely a 7mm will not be accepted. Even if it does work, you will need to be careful to not set the stitch width wider than the 7mm will allow.
May 09, 2018 | Janome Sewing Machines
On my Janome Skyline S5 error S on display. Can't change mode
Am wondering if it's actually a 5. Check that the bobbin winder has been deactivated.
Feb 05, 2018 | Janome Sewing Machines
I have a a Janome Skyline S5. Error of S on display
did you look in the instruction book for that problem ?
did you call the repair facility to inquire whe that means - and steps to alleviate the issue?
it may mean repair facility technicians must work on it. you need to find out before attempting user 'fixes'.
My janome me 10000 keeps giving me a warning message that says is fabric to thick is needle bent is something stuck in machine. I just had a new circuit board put in. Why is this doing this
That is the wierdest error message I've ever seen on a sewing machine. Did you try a brand new needle? Are you sewing thick fabric (does the message appear when sewing light-weight fabric? Remove the bobbin case from the machine and check for thread wrapped somewhere. If you are not able to find an answer on your own, then it's probably best to take it for service.
Janome MC10000 Warning Machine Wont Sew
Jan 28, 2018 | Janome Sewing Machines
Janome 10000 - I get a warning message and the machine quits. I've had it to a repair person 4 times
If you've had it in for repair four times, then the technician is not doing a good job. Take it back and insist it be fixed... talk to the manager and relay your dissatisfaction with the service. OR ask for a refund and take it to a reliable Janome technician.
You don't mention the error message, so it is very difficult to try to assist.
Oct 22, 2016 | Janome Memory Craft 10000
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
