If this Stops him from getting elected I will blame your station! EVEN though it is my 24/7 favorite channel PLEASE sent to correct place Rebecca Kosbab ,
SOURCE: Agitator
got a model # It may be in the gears of agitator if you have a 2 piece agitator... is the bottom of the agitator moving still when you say it stopped ?? AND Its Just Top of agitator stops?
SOURCE: Hard reset for Wash cycle too long posted by thsparky 6/10/08
turning it for 24 hours by removing the pulg from the wall socket.
then after 24 hours try to press start(or any equivalent button to start the unit)
u must not see any kind of movement in unit since u r not connected to power.
this is done to drive off the unnecessary power from the unit that we dont need.
now you are done.
if everything goes fine you are done.
SOURCE: Samsung plasma. adding channels to favorites.
open tv manual setup cable to ant
auto scan channels
SOURCE: Can't find link: "Report Abuse"
Put the http address in your restricted addresses in control panel under internet optons.
SOURCE: PHILLIPS HTD 7001 IPOD DOCKING STATION
for this kind of unit HTS8100 that comes with htd7001 it can only play some ipod. for instance if you want to play music you can use ipod nano but if you want to play video you need to use ipod 4th and 5th generation. because there's compatible issue with this unit because ipod was released after this unit (hts8100) was released
