SOURCE: tascam us122 audio/midi interface driver for windows xp
What is your computer and operating system....?
Oh, and go here...
http://www.tascam.com/details;9,15,68,19.html
Keep me posted.
SOURCE: Modem connection
Your modem should have a RJ11 (phone) jack and a RJ45 (ethernet) jack. Phone line-in to modem RJ11. Ethernet cable from RJ45 to modem to router; maybe labeled WAN or modem port . Ethernet from any of the switch ports (or the only one avail, depending on your model) to you pc if it has a ethernet card in it. After that it's all up to the configuration.
SOURCE: Unable to connect my LG KU990 to laptop using USB cable.
If you are trying to connect your LG KU990 with Data Service, you have to isntall the drivers for it. The drivers should have come with the small CD.
If you want to change to Mass Storage mode: Menu>Settings>Phone Settings>Connectivity>USB Connection Mode>Mass Storage.
Regards,
Max
SOURCE: Hello, I have a Tascam us122 usb audio/midi interface
http://www.zoom.co.jp/english/download/software/gba21u.php#c
Check this link out.
SOURCE: recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
