Hi, the two equipments are amplifiers, and the Sony is also Receiver, the possible connections are level, low signal and you can leave the "REC OUT" of the Sony and enter AUX in the Sansui, in this way, everything that comes in stereo on the Sony, will exit by rec out and enter the auxiliary on the Sansui
Hola, los dos equipos son amplificadores, y el Sony ademas es Receptor, las conexiones posibles son a nivel, baja se?al y puedes salir del "REC OUT" del Sony y entrar a AUX en el Sansui, de esta manera, todo lo que entra estereo en el Sony, saldra por rec out e ingresara al auxiliar en el Sansui
SOURCE: I NEED INSTRUCTIONS ON HOW TO CONNECT ALL COMPONENTS TO THE SONY STR-DE598 RECIEVER
codes for remote
SOURCE: sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
SOURCE: Can I hook up a photo turntable to a sony str-de435 receiver?
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
SOURCE: can I hook up a fisher (EQ-961) to a sony
Yes, see the other request you posted:
http://www.fixya.com/PostComment.aspx?thid=4196867&prdid=0&ctgid=109
