SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: I have a GCVH6260FWW GE Front Loader. It will not
Yes you should see it - and call an electrician they can legally disconnect the "water saver" or adjust it safely
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
SOURCE: how can I get a manual?
If you need to clean the drain pump reservoir, or inspect it for debris, the following link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
There is a tech data sheet that comes with your washer that lists troubleshooting advice and error code explanations. The sheet will be located behind the lower kick panel directly under the door. If not affixed to the panel, it will be located along one of the interior cabinet walls. Its recommended that you leave it inside the appliance when not in use, to ensure it does not get lost.
If you are looking for an Owner's Manual (operating instructions), managemyhome.com has a huge library of downloadable manuals for FREE. All you have to do is register. Once registered, log in and click on the "Owner's Manuals" link under the "Home Manager" drop down menu.
NOTE: If cleaning the pump does not correct your problem, it is recommended that you replace the drain pump.
If you have any questions, please let me know. I hope you find this information helpful.
SOURCE: E20 error on Kenmore front loader. The water is
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
•Verify there is not a siphon problem
•Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
•Check all hoses for possible leaks
•Verify pressure switch operation
•Verify flow meter operation
•Verify CCU operation
