Electrical Supplies Logo
Ken Fraser Posted on Apr 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much oil does twm8000 generator take. - Electrical Supplies
Jamie C
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Apr 03, 2019
Jamie C
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
727
Points
23
0.9 qt/L is what is needed to do an oil change
Marvin
Level 3:
Top Expert:
  • Master 85,242 Answers
Marvin
Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057109
Points
266281
Insufficient info to help you
1helpful
2answers
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
2answers
Diesel generator
1. Heat dissipation, cooling and clogging of the lubrication system cause the diesel engine to overheat.
Blockage of radiator or pipeline: once the radiator and pipeline are blocked, the cooling water cannot circulate and the diesel generator will overheat.
Exhaust pipe blockage:When the exhaust pipe is blocked, when the diesel generator is running, the exhaust gas is not discharged smoothly, and some of the exhaust gas remains in the cylinder. When the next intake stroke is intake, there are more in the cylinder. Exhaust gas, fresh oil and gas mixture can not fully come in. When the spark plug is ignited, the flame propagates and burns slowly, and then burning time is long, forming a post-combustion. Parts that are in contact with gas, because of the long burning time, can not release heat, thus causing overheating, at the same time, due to the unsmooth exhaust gas emissions, the exhaust gas temperature rises significantly when exhausting, and the thermal load of the entire diesel generator increases, causing the generator to appear overheat.
Oil filter plugging: Under normal conditions, the oil of the diesel generator enters the diesel engine through the oil filter. Once the oil filter is blocked, the oil enters the lubrication points of the diesel engine only through the bypass passage. In this way, since the oil is not filtered, it is easy to bloc the oil pipeline, causing poor lubrication, the oil pipeline is blocked, and the heat generated by the friction coupler can not dissipated, causing the generator to overheat.
Oil screen plugging: The oil filter is placed at the inlet of the oil absorber in the oil sump to remove foam and prevent large slag from entering the oil pump. Once the oil filter network is blocked, the supply of lubricating oil to the diesel generator is interrupted, which will cause dry friction of the friction coupler of the diesel generator, which will cause the generator to overheat.
2. The cooling system and the lubrication oil system leak, causing the diesel engine to overheat.
Leakage of the radiator or pipeline: The radiator or pipeline leaks. Because the water storage capacity of the diesel tank is limited, the generator will overheat.
Oil pan or oil pump oil leakage: The oil pan or oil pump oil leakage is mostly caused by loose oil plug or gasket damage. The consequence of the oil sump or oil sump leakage is that the diesel generator oil supply is reduced or interrupted. Since the diesel generator reduces the cooling effect of the oil, the heat of each friction pair of the diesel generator cannot be transmitted, so that the generator is overheated.
More information at this article: https://www.dieselgeneratortech.com/diesel-generators/How-to-Deal-with-Diesel-Generator-Overheating-Problem.html
2answers
What type of oil is required for this generator
You have not specified the make and model of the genset. Usually the normal type oil used for petrol /diesel engines can be used typically the grade 40.
Please look up on the manual to be more specific.
I put too much oil in my generator
Drain the oil again, and re fill ! too much oil will blow engine seals
1helpful
2answers
How to change the alternator on my 2000 grand voagear
This is for a 3.3L motor
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
REMOVAL
  1. Release hood latch and open hood.
Removal/Installation of Battery Cables 81929864
  1. Disconnect battery negative cable.
  2. Remove windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  3. Remove accessory drive belt.
Generator Mounting Bracket 81929870
  1. Remove bolt holding top of generator mount bracket to engine air intake plenum.
  2. Remove bolts holding outside of generator mount bracket to generator mount plate.
  3. Remove bolt holding top of generator to mount bracket.
  4. Remove generator mount bracket from vehicle.
  5. Rotate generator toward rear dash panel.
Generator 81929868
  1. Disconnect the push-in field wire connector . from back of generator.
  2. Remove nut holding B+ wire terminal to back of generator.
  3. Separate B+ terminal from generator.
Generator Pivot Bolt 81929871
  1. Remove bolt holding bottom of generator to lower pivot bracket.
Generator 81929872
  1. Remove generator from vehicle
INSTALLATION
  1. Place generator in position on vehicle.
  2. Install bolt to hold bottom of generator to lower pivot bracket.
  3. Place B+ terminal in position on generator.
  4. Install nut to hold B+ wire terminal to back of generator.
  5. Connect the push-in field wire connector into back of generator.
  6. Rotate generator forward away from dash panel.
  7. Place generator mount bracket in position on vehicle.
  8. Install bolt to hold top of generator to mount bracket.
  9. Install bolts to hold outside of generator mount bracket to generator mount plate.
  10. Install bolt to hold top of generator mount bracket to engine air intake plenum.
  11. Install accessory drive belt.
  12. Install windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  13. Connect battery negative cable.
  14. Verify generator charge rate.
1helpful
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
1helpful
2answers
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
1helpful
3answers
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
