2019 model Quantum
SOURCE: maintenance costs
Oil change will cost about $200, tires? depends how and how much you drive and quality you buy. Guess you could spend $200 each. Brakes depend how much you drive but a quality brake job will cost about $1,000. As far as daily driver?well this car is not designed for that, and will probably suffer in stop and go traffic. So would need a tuneup about every 4-6 months at a cost of about $2,000. then you need a mechanic that is trained. Hope you can find one in your area.
SOURCE: Goodman PGB042100-1 REVA Flame sensor not working; no heat
try national energy they will give you a price you will need make model and serial number 600 is high you should be able to get it for a lot less
SOURCE: write a mathematical model representing the total monthly cost
Mathematical Model for the problem:-
Option1: C=42+5*x
Option2: C=0+ 8.5*x
Thanks
Zulfikar Ali
[email protected]
09899780221
SOURCE: GM Daewoo Kalos - Excessive fuel consumption 15L/100km
o2 sensor bad or ,dirty or clogged injectors hope this helps
