Question about Dewalt Tools & Hardware - Others
Speed control wire around on DW423 sander - Dewalt Tools & Hardware - Others
  • Dewalt Master
  • 4,320 Answers
Try this link:
https://www.ereplacementparts.com/dewalt-dw423-type-inch-evs-random-orbit-sander-parts-c-1009_2742_2758.html
Posted on Apr 02, 2019
2 Suggested Answers
SOURCE:
efs_perpends
  • 1996 Answers
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
No powerto sander. Cord is good,switch is good and brushes are long
It sounds to me that you have used the sander a lot and the vibration has broken a wire or it's about to break on the field windings. The brushes you need to look at to see if worn. But I kind of think wire problem. I had this happen on mine and opened it up to find this is what happened. The sander would be turned on and would not operate until I turn upside down and it would work. This is great if you are sanding upside down but this is just a sign that you are on borrowed time as this will eventually not turn on at all. I was able to fix mine with new wire crimp connection and solder with heat shrink material. If not you can order new field winding if this is what is wrong. Cleaning up the sander won't hurt either. You might want to see what a new sander will cost vs. part. Good Luck!
Aug 23, 2012 | Dewalt Sander,random Orbital - DEWALT
Bosch ROS not powering on
Checked the net for answers and got a couple of maybe's. 1.) Brushes, 2.) variable speed control, which some were direct wiring.
I tried the brushes firs and that has solved the problem for now. I guess the brushes stuck or somehow lost contact.
I got a parts diagram and found the brushes (will be covered with dust). Took the springs out and stretched them a little, replaced and the sander turned on. You will need to remove the top cover to do this. Verdit is still out as to long term performance. Not a great start.
My particular sander was lightly used (second project) and it has not been abused.
Jul 11, 2009 | Bosch 1295DVS 5" Palm Variable Speed...
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Need a wiring diagram for a delta drum sander
Hope that helps...
Feb 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Air Sander Question
When you are finishing the surface of wood, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
Aug 27, 2008 | Taylor Pneumatic: Orbital Sanders:...
Speed Control Question
Aug 27, 2008 | Coleman Powermate 024 0091CT High Speed...
Tools & Hardware - Others Logo
76 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
