WIFE AND I RENT DOWNSTAIRS PORTION OF A HOME BUILT 1962. THE POPERTY RUNS OFF A WELL WHICH CREATES ALOT OF CALCIUM BUILD UP. THE FLEX PIPE THAT HOOKS FROM DISHWASHER TO WATER LINE IS CORRODED BADLY AND IT LEAKS. IS THER ANY EASY FIXE BESIDES CHANGE OUT PIPE, PROBLEM IS THAT THE OWNER IS CHEAP SO THE EXPENSE IS GONNA BE ON ME. HOW CAN I REGULALRY MAINTAIN CALCIUM DEPOSITS AND PATCH LEAKY HOSE
SOURCE: Stops working after 2 minutes and "Rinse and Hold" keeps flashing
when you open the door, there is access to screws around the inside edge and under the front lid, where the rubber lip is and down the side, remove these and the appliance should pull out gently
SOURCE: 1999 kia sephia leaking antifreeze
I have a 97 Sephia with what sounds like the same configuration. The tube is for the heater and there is an "O" ring on the metal tube that goes bad over time. You can replace the gasket by removing the metal tube from the engine, or the water neck and replace the o ring.
SOURCE: Sounds like dishwasher is running but no water coming out (there are no broken pipes or leaks)
I had the same problem. The motor is working (humming) and my dishwasher goes through the whole cycle without water. I googled it and found it on a website. Sorry I don't remember which website. Basically, it said to put some hot water in the bottom of your dishwasher and add some citric acid. I added 2 small packets (2 oz each) and filled the bottom of the dishwasher with hot water until it covered the motor or the drain of the dishwasher and left it overnight. The next day my dishwasher started and ran perfectly fine. That was over 4 months ago and I have not had any problems.
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
SOURCE: 2005 Ford Focus flex pipe repair
Advance auto and auto zone sell just the flex pipe. You will need to have someone cut the old one out and weld the new one in. costs about $20 for part vs $300 for pipew/catalitic converter attached.
