Question about Pride Health & Beauty
Pride pursuit key barrel change - Pride Health & Beauty
2 Suggested Answers
SOURCE:
  • 5320 Answers
SOURCE: pride pursuit has little power in reverse
I am not an expert on such things but I have had a little experience of a mobility scooter with a similar symptom or fault.
Speed control is by a switch-mode power supply and reverse is by circuitry and relays (or SCR's) that change the polarity of the supply.
The fault on Sam's just-out-of-warranty scooter was caused by an electronic fault in the polarity change circuitry, which was just a small part of the large single circuit board. I approached the manufacturer who told me no repairs were possible and a complete new board would have to be purchased at a huge cost.
I argued the point on behalf of my customer and finally a new board was sent free of charge which put matters right.
I fully expect your problem is likely to have a similar cause, though you might be fortunate enough to be able to obtain circuit diagrams for local repairs, a manufacturer repair or a refurbished board at a reasonable cost.
A possible cause of such faults might be the weakening effect of electricity surges in the supply during battery charging. It would be wise to only charge the batteries when a surge protector is used in the mains supply, such as is recommended for all mains powered electronic devices including computers.
I hope this helps.
Posted on May 30, 2016
Pride pursuit has little power in reverse
I hope this helps.
May 30, 2016 | Pride Health & Beauty
Flash code 8 motor voltage error means
Hi get in touch with pride www.pridemobility.com.au ...good luck
Mar 07, 2016 | Pride Pursuit - 4 Wheel Scooter
What does 2 flashes mean? My pride pursuit flashes 2 times and won't move. The motor and programmer were replaced but the same 2 flashes appear.
hi, that means it cannot see the motor resistance... it should read about 0.1 to 1.0 ohms only ...
Check the connection from the motor to the controller.. please disconnect one battery before doing this so you don't accidentally short anything ..
I'm here or on facebook if you need further advice...
Regards
Rob
www.facebook.com/gewizrepairs
Aug 16, 2015 | Pride Health & Beauty
My Pride mobility Pursuit has an uneven throttle response. A very light touch on the throttle lever causes the scooter to surge forward (or reverse).
Your best bet is to replace the throttle potentiometer. This can be purchased from the manufacturer Pride Mobility part#FRMASMB15318 or from Monster Scooter Parts:
http://www.monsterscooterparts.com/throttle-pot-pride-pursuit.html
Always verify model and SN compatibility before ordering.
I ran your serial number and it did not return any results in the Pride Mobility database
Mar 14, 2015 | Pride Health & Beauty
Why is my pride pursuit scooter dead... no lights anything
Sounds like the water has damaged the controller or the wiring.
Oct 19, 2014 | Pride Pursuit Xl Heavy Duty 4-wheel...
Pride sc713 fault 8
hi , hopefully a loose connection to the controller, otherwise a controller repair is required...
Regards
Rob
www.gewizrepairs.co.uk
Jun 18, 2014 | Pride Pursuit Pmv SC713
Key broke in barrel
Hi Debbie, pelase contact me and i can supply you a new low cost barrel with institutions on how to fit it.
Regards
Rob
Mar 06, 2014 | Pride Go Go Elite Traveller Plus 4 Wheel...
It is a crying shame moter went out on my pursuit under warrant early july have not got replacement yet i know that there should be one in stock i am sure tha there are be produced as i speak
chase them up, and threaten legal action if it is not with you by the end of a week, they are legally responsible, use your rights or if your disability is to restrictive for that get a friend or if in UK trading standards to help.
Sep 04, 2013 | Pride Mobility Pride Pursuit XL FREE GIFT...
Pride Pursuit XL scooter won't charge
Is this the Pride Colt XL 8 scooter ? if so look at the steering column, there is a fuse here for the charger ?
Please give feedback.
Dec 19, 2012 | Pride Mobility Pride Pursuit XL 4 Wheel...
Health & Beauty Logo
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
