Question about Food Mixers
The dough hook got stuck and I need to replace both hook and gear box where can i find the parts?
    Top Expert:
  • Food Mixers Master
  • 63,117 Answers
Go look at where they sell the item you have perhaps they sell new machines there
Posted on Apr 03, 2019
SOURCE:
SOURCE: Replacement parts for K-Tec Kitchen Machine
I just talked with Blendtec about this issue, since I had the same problem. I asked if there was a stronger drive shaft since my previous Kitchen Champ model had a different, sturdier drive shaft that lasted about ten years.
The company representative explained that the new drive shaft is designed to break, but that's to save the motor. If the stress on the drive shaft could damage or cause excessive wear to the motor, the drive shaft breaks instead.
She also recommended using just enough flour so that the bread dough pulls away from the sides of the bowl. The reason most drive shafts experience too much stress is due to too much flour in the recipe.
To replace the drive shaft, go to http://www.blendtec.com/Parts.aspx or call Blendtec at 1-800-Blendtec
The only part that will work for the Kitchen Champ is the Drive Shaft (Champ). Apparently, the German drive shaft -- which looks like the one from my old Kitchen Champ -- is not interchangeable.
Since this is my second Kitchen Champ and my previous one lasted over ten years, I'm delighted to understand what went wrong. I'm hopeful that using less flour will prevent another problem. And, I'm very pleased with how helpful Blendtec was, explaining this to me.
Posted on Jan 20, 2009
  • 297 Answers
SOURCE: a part of the KitchenAid stand mix came off...
They give only one year warranty. But these devices are not so complicated.
Have the right handy guy a look at it. You know anybody on the block?
Else you have to go to a repair shop. Diagnozing her from here is undo-able.
And still not fixed over there. I think it is a small thing.
Posted on May 02, 2009
wiringlunati
  • 576 Answers
SOURCE: need to know the part number for a dough hook for
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Posted on Jan 05, 2010
SOURCE: The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Posted on Jan 24, 2010
  • 51971 Answers
SOURCE: broken gear
Refer this problem directly to Hamilton Beach as the primary source of the parts.
Posted on Dec 12, 2013
What is spiral hook dough?
A Spiral Hook Dough Hook is one that is used for making bread dough. It mimics the action of stretching and kneading the dough by hand. This develops the gluten content which is the elastic part of the dough that traps the bubbles of carbon dioxide from the yeast.
Oct 14, 2017 | Food Mixers
Broken gear
Dec 12, 2013 | Hamilton Beach Eclectrics All-Metal Stand...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Kitchen aid mixer has a scream when using dough hook.
A little pin or setscrew or key has failed. Maybe a gear has slipped out of place. Anyway, the thing needs to come apart to find out what happened. When taking things apart, line up each item off in a tidy row, put screws in little containers near the part they fit.
Repairclinic.com may have instructions, and probably have the parts.
Nov 26, 2013 | KitchenAid Food Mixers
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Mixer stopped turning when I was making bread
You probably have stripped the gear in the head section. It can be replaced, but I would consider this a advanced repair since you need to push steel pins out of the shafts to replace the gears. Use google to find a local repair shop, or fix it yourself if your mechanically inclined, parts are available online (and not that expensive).
Sep 26, 2008 | KitchenAid KP2671 Professional 6 Series...
Help with removal of Dough Hook on A200.
Force and a torch is your path.
First cut a block of wood that is of a length that is long enough to go from the column to the attachment portion of the planetary. (The block protects the gears from the force.)
Look at the rotation of the hook, you're going to twist it the opposite direction. Above the hook, loop a strand of a wet towel. While keeping the towel damp, not wet, torch the **** out of the hook. I recommend "mapp" gas. Heat it for about 90 seconds to to 2 minutes. The old dough stuck inside will burn off. You should get some black smoke. Use the block of wood, between the attachment portion of the planetary and the column, to resist the twist of the hook. If the wood is properly placed to absorb the load --- dampen towel, torch, block, TWIST. If you use a wrench -- be cautious. Good luck -- Mike
Jun 27, 2008 | Hobart A200 Stand Mixer
Viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Feb 18, 2008 | Viking VSM700 Stand Mixer
Food Mixers Logo
29 people viewed this question
Top Food Mixers Experts
Bruce Showalter
eyecam
Marvin
Marvin
Are you a Food Mixer Expert? Answer questions, earn points and help others
