I see that you are having issue with using the camera on your Lenovo with other programs such as Skyp or Yahoo Messenger and so on...
On your Lenovo the camera works with easy capture, that is a good sign saying that your camera works but how to make it work on other applications you will need to get in the applications settings and select the Lenovo Camera as a default device for that specific application that you are using to utilize the camera.
all the applications you mentioned earlier has thier own settings page and this is where you can set each to make the Lenovo Camera the default deivce for it to work on your applications.
I hope that this will help you with your Camera concern.
The application you are running may not work with the version of Java currently on your phone. You need to refer to your users manual on errors of application faults.
You can use the applications which are in .CAB format directly from the phone. You just need to copy this application to the phone and run the application.
If the application you have is in .EXE format, then you need to synchronize the phone with your PC via USB cable or Bluethooth device and run the application directly from your PC.
this could be one of 2 things either the main camera(2MP) or the vga(video call) is faulty. you need to test the vga camera by going onto the video call mode. if that works then its the 2mp camera.
hope this helps...
any further questions I'll be happy to help.
g
Try to increase its resolution next to 800X600 or this version maybe works at this settings, version 9 needs 1280X800. Try to adjust the resolution first before you run the application. Or check your driver. Or reinstall ulead with the resolution set to 1280X800.
Reinstall the driver for the webcam and also the application to make it work. If this do not resolve the issue you need to get the connectivity checked.
If your windows operating system and microsoft office application program are license to microsoft you need not need to purchase that said application, because that is the bug of their program and needs only updates, else if the this not encountered before and you have all the installer of this said application program. you have to unistall the program and reinstall it again after restarting the system.
