Is it possible to connect three decoder on one dish
677A Legakabe Street Zone 7 Meadowlands Soweto
    Top Expert:
  • Audio Player... Master
  • 63,108 Answers
Sorry but you need to ask your satellite service provider but my guess will be no
Posted on Apr 03, 2019
SOURCE:
Dish connection is not working
Check:
coax connection is tight at LNB and decoder,
coax cable is not damaged,
decoder is working,
account is valid & up to date,
dish is aligned correctly.
Otherwise get somebody with a SATFINDER or similar signal strength meter to confirm there is a signal.
Nov 20, 2017 | Televison & Video
We can not connect to Dish receiver
Check cable between decoder and dish
May 24, 2015 | Televison & Video
Autosetup on my DVB is not picking up stations. The TV is connected directly to the satellite dish and has all free sat stations. As far as I can see all the connections between the TV and DVB are as
I'm wondering where in the mix is your satellite receiver? The recorders currently on the market aren't able to decode digital satellite signals. They are capable of decoding cable but i'm unaware of any that work on satellite.
Sep 17, 2014 | Panasonic Televison & Video
Hello, I have a sky dish and decoder, but before the decoder I have put a splitter and carried a seperate coax straight to another Freeview tv hoping to get a signal... But it hasnt. Is it possible to...
David.
Are you using the same output from the LNB on your sky dish?
ie one cable??.
If you are it will not work you need to use a seperate output,
if you cant do this,you will need to change the LNB to a multi output one.
By the way there is 30 volts present all the time from your receiver to your LNB, that is even while switched off.
Jun 02, 2014 | Televison & Video
Strong decoder
check the dish if its a dish or cable if is a cable tv connection
Jul 04, 2013 | Televison & Video
I have no picture on my tv set only sound. The tv is connected to a satellite dish and decoder
Try to check the video cable that is connected to your tv and you decoder it may loosed or damage. hope that this may help.
Jul 11, 2011 | Televison & Video
I need to dezone my dvd player panasonic XV N 670B (bought in a US shop, zone 1, but I live in Europe , zone 2)
Not possible, sorry.
Region code in Panasonic DVD player is not possible to break.
Thanks.
Aug 16, 2009 | Televison & Video
I want a diagram of 4X16 multiplexer circuit ..................
it's not a multiplexer, that's called an encoder.
Multiplexers are sort-of like switches. They "choose" one of the X inputs based on an input "selector" and output it
http://en.wikipedia.org/wiki/Multiplexer
but what you're looking for is something that decodes a 4 bit binary input into a 16 bit output where for each possible input, one unique outputs out of the 16 are high. That's a four-to-sixteen line decoder.
They're kind of useless. Three-to-eight decoders are much more common.
Here's an article on how decoders work, and it shows an example of a three-to-eight line decoder. You can easily take that and extend it to be a four-to-sixteen line decoder once you understand the process.
http://cpuville.4t.com/decoder.htm
Dec 04, 2008 | Computers & Internet
HOW CAN I SETUP PROGECTOR WITH DISH NETWORK?
Hi YOLANDAZUNIG
You will have to give me an idea of what outputs your dish decoder has got and what inputs your Projector has got.
Normally you would use the normal RCA ( Video Connection )
You'll see at the back of the decoder there will be 1 with a yellow ring around it - That's video , and another two with red and white rings respectively - for Audio.
Make sure you connect the cables according to colour from the decoder to the Projector.
May 21, 2008 | Radio Shack Cinego D-1000 Multimedia...
No output to Zone 2 from preout to 2nd power amp for second room speakers
OK, From what I am understanding is that you both are trying to uilize a digital audio source (HDMI cables are digital audio only) and hence this is the problem. You can only use an analog audio source (connection) to utilize the audio output to zone 2. A simple soultion is to use the analog audio in conjuction with the digital. Connect the digital (HDMI, Optical, Coax) to the main zone and the left and right audios to zone 2.
Dec 22, 2007 | Denon AVR-3803 Receiver
 Grubhead
Grubhead
Marvin
Marvin
