I am looking to find the next thing to check... mainboard, inverter, power board, any suggestions? Sound is fine, picture is bright on hdmi,av,pc inputs. go into picture set up and change
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: My Sony BRAVIA KDL-46V3000 Television has messed
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Testimonial: "You were so right. Thanks."
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
