SOURCE: Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
SOURCE: Technics SL-MC6 CD player
a) the current CD in use is in slot 23
b) behind slot 23 is a CD left inside
SOURCE: dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
SOURCE: How do you install the belt in a Technics LP SL-B300
assuming that you have the correct size belt, remove the platter and place the belt onto the platter (bottom side). Replace the platter and using a pencil, grab the belt and place it around the motor hub. The slot in the platter should give you enough room to do this. Dan
SOURCE: technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
You say broken, as in, what is it doing or not doing? Everything is serviceable and Technics-Panasonic are simple to service-repair, what State are you in, depending on the issue or issues with it, I can bring it back to life in 100% perfect working order for under $50.00 and one to two day turn around time, ship it to me and prepay return shipping, (Note) see my feedbacks on Letgo in Fairfield California under Supertech99, 100% positive feedbacks with 5 star all across the board, I've been repairing Audio~Video components for over 40 plus years, with zero recalls and I also guarantee all my repairs for the period of 90 days.
Hi. I’m in the UK and I’ve already tried to have it repaired here. The part it needs is out of production and there were none available on eBay. I can’t remember which part however. I’m happy to replace it and just need to know if the models are compatible. Do you know if they are?
