SOURCE: tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
SOURCE: audiovox twin dvd players for car keeps blowing
You will to buy a fuse with a higher amp rating
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Audiovox PVS72901
SOURCE: taillights and license plate lights not working
there is a short somewhere.put a test light in place of the fuse.
the light will glow bright.when the short is removed,the light will go dim
SOURCE: it keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
