Question about Sanyo Televison & Video
I have a Sanyo 55" LCD TV MN FW50D36F it often when starting has the picture jumping and if i shut it down and wait 2 minutes it starts up OK. Is there a board i can replace to fix it?
SOURCE:
  • 65 Answers
SOURCE: Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Posted on Dec 09, 2006
SOURCE: Sanyo PLC-XT16
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
  • 108 Answers
SOURCE: red haze across top
Replace the optical block assy
Posted on Jan 11, 2009
SOURCE: Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Posted on Apr 08, 2009
  • 122 Answers
SOURCE: 40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Posted on Mar 09, 2010
Where can I get a replacement remote for a FW50D36F Sanyo tv
Fixya is unable to identify sources for replacement remote controls.
Mar 20, 2018 | Sanyo Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Sanyo flat screen lcd 46 inch
Probably the power supply is failing intermittently, just shutting down without affecting picture or sound.
Mar 10, 2014 | Televison & Video
Set starts up back light comes on No picture. After 1 minute set shuts down. Regulator on ssb board gets very hot. I would like to replace small signal board. Who supplies patrs for that unit
Hi
You can get if from authorised service center for Sanyo. If it is not availabele there, get into the websites of Alibaba.com, RS Components, Mouser.com etc. You can select it from their electronic sparepart collections. Can buy it by E-payment. OK.
Jul 11, 2011 | Sanyo CE42LM4N-NA 42 in. LCD TV
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
