SOURCE: bunn pod coffee tea brewer
Visit the Bunn website on the following link: http://bunn.com/retail/service/faq.html You can download manuals, read the FAQ & get telephone support from them. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Coffee Brewer comes out warm not hot
look at the top of the coffee maker you'll see two screws and the warmer tray and the cover for adding water. remove the two screws and lift the top off. the warmer has two push on spade terminals. pull the wires off them. below is a tray where the water goes and you'll see a brass bushing. this is screwed into a fitting on the water tank. use a piece of steel as a spanner and unscrew this fitting. don't lose the gasket that's under it. the main wires for the burner element and thermostat are also under this tray. look at the top. there's nine screws that hold the top on the water tank. two white wires go to the tank warmer and two wires go to the tank heater inside. you can try turning up the thermostat setting to a higher range and see what happens. there's a copper pipe that comes from the tank to the sprayhead the tank holds approx three urn fulls of water. if you have an analog meter you can check the element for continuity on the RX1 range. Do the same with the tank warmer element. Bunn-o-matic has a web site you can buy replacement parts or nelson appliance can get you parts too.
SOURCE: bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
SOURCE: Bunn 10 cup home coffee brewer is leaking from the
These models have a plastic pour-in tray just under the top lid. The plastic on these trays gets brittle over time with the heating and cooling, and they crack where they mount to the tank. The only real way to repair this is to replace the pour-in tray, but these are not sold anywhere that I have found. You might be able to find a used one at a Bunn dealer in your area.
I have seen some people do a temporary repair by putting a washer under the mounting bolt and sealing it with silicone, but this is a temp. fix at best. By the way, the reason that the water appears to be coming from the bottom of the machine is that there is no other place for the water to come out after it leaks from the top.
SOURCE: Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
