Question about Necchi Sewing Machines
Where can’t i find a needle clamp for a Necchi Supernova Ultra ? Having problem locating one, thanks in advance
    Top Expert:
  • Necchi Master
  • 52,781 Answers
Fixya is unable to source Necchi parts.
Posted on Apr 01, 2019
SOURCE:
  • 3 Answers
SOURCE: My needle will not stay threaded. It gets gobs of
try rethreading, make sure the foot is up, change the needle, make sure there are no loose threads or lints under bobbin case. You might also try rewnding the bobbin to make sure it is wound evenly.
Posted on Jun 20, 2009
SOURCE: VALUE OF NECCHI AUTOMATIC SUPERNOVA ULTRA MARK 2IN
in Italy I have bought it by 25 euro :) - yesterday ;)
lisa@foxy-jewellery.com
Posted on Feb 28, 2010
SOURCE: Necchi 215A Sewing machine Could anyone help I
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Posted on Sep 27, 2010
Testimonial: "Thanks for the answer it did not work for me though"
SOURCE: I have a necchi model
if the sewing machine is not sewing & staying in one spot the that means the feed dogs are not working properly.
I also have a necchi sewing machine, check the needle plate area that's where the feed dogs are, if the feed dogs are up where you can see them & even feel them with you fingers when you rub your fingers over the needle plate area, if you can't see them good or feel them, then they are not up,,my instruction book shows that you have to remove the extension table, their should be a small door in front of the needle plate area to open that's where the feed dogs are if they are not in the up position, where you can sew, if they are in the down position move the lever to the opposite direction & see if that help the machine to sew, if it make makes no difference which position there in , then it's possible something is wrong with the feed dogs & the machine needs to be serviced
Posted on Sep 18, 2011
  • 1564 Answers
SOURCE: My mom has a Necchi supernova ultra that needs a new belt. What is the correct size and where do I find one?
Just measure the existing belt and go from there. Besides the supernova and supernova ultra are likely to use the same belt.
Posted on Sep 13, 2012
Who manufactures the ultra dressmaker free arm sewing machine?
NO idea look on the machine for a name like SINGER
Jan 09, 2016 | Sewing Machines
Necchi needle bar screw
it would have been helpful if you had provided the model number of the Neechi sewing machine.
But if you go to this website you should be able to locate the correct part for needle bar clamp and screw.
Necchi Sewing Machine Parts
Aug 05, 2014 | Necchi Sewing Machines
Necchi supernova manual
Most sewing machines can use a double needle, the one with the single mounting shank and it turns into two needles.
MAKE sure you have Zig Zag needle plate installed to accomodate the double needle.
Turn hand wheel slowly to test then use thread and fabric and turn flywheel by hand to test sew.
Jul 19, 2014 | Necchi Sewing Machines
Sep 07, 2012 | Necchi Sewing Machines
Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
Apr 24, 2009 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
