SOURCE: wii console
Did you try turning the disk over so the label shows on the opposite side. With the Wii you have to put them in upside down it seems.
SOURCE: Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
SOURCE: "Unable to read disc" Wii
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
134
SOURCE: unable to read disc message on Wii
Try a cleaning disc. this may fix this issue. if the issue remains, it will confirm a major problem within the optical assembly. you will need to replace the optical assembly in this case. it has failed.
Contact Nintendo for the optical replacement procedure.
