SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever
heard of this? Part runs about 300 bucks. TV is out of warrenty as it
is 2 years old. Do you think it is worth it to fight sony and get them
to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
SOURCE: Sony KDF-E50A10
Replace the lamp, sounds like a weak or old lamp. Use an original Sony, the replacement lamps are unreliable
SOURCE: thermal fuse on sony KDF-60XS955
check out link below for part. i have 55cs955 and just ordered one. I still do not know where to find in TV but as most post says its somewhere near lamp housing.
http://www.partstore.com/Part/Sony/Sony/191002393/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDF55XS955
SOURCE: My Sony Wega rear projection TV has green
I hate to tell you this but if your light enginge /optical block is bad you are Looking at just for Part $1,949.95 core refund is $1,300.00 Then part is 649.95 Encompass Parts Distrubtion has 23 of them
1-800-638-3328 Chances are it is your Light Engine!
SOURCE: Sony KDF E50A10 tv starts up but then shuts down
most likely power supply fault buddy/get part no search google
