Hardware not installed, not system specific
SOURCE: Macbook airport
you should try a software update first along with a PRAM and SMC update (hold the power button down when the computer is off for 15 seconds-it will beep. immediately after that hold down the Apple, option, P and R keys simultaneously until the computer reboots and chimes 3 times)
SOURCE: Cannot connect my new Apple MacBook Pro to mt DIR
No -there are no drivers to install. I would even suggest not to use any CD that came with the router (in your case the so-called "Quick Router Setup Wizard CD".
It is always better to configure the router by hand, otherwise you have to look forever if you have to troubleshoot.
If you connect your Mac to your DSL- or cable modem, can you access the internet?
If yes, then you have to configure your router. If not, then there is a problem with your internet connection in general and you have to contact your ISP.
Connect to your router (via cable) and check that the SSID is broadcasted and your wireless security is turned off, until you can connect wireless to your router. Look at the manual page 22 (if you don't have a manual, you can get it here.)
Then follow the Wireless Security Setup Wizard (ideally do it manually, but this works too). You find a description up from page 64 in your manual. For now, select no wireless security and complete the wizard. Don't forget to save your settings.
Now you should be able to connect to your routerwireless from your Mac.
After this is accomplished, go back to the wireless security setup and secure your network with WPA2 Authentication.
If you have any more questions or get stuck at one point, just come back here and leave a comment - I'm happy to help.
SOURCE: My MacBook is making a purring noise.
it can be the cooling system, but you will have to show your machne to a reparator.
SOURCE: macbook air internal mic not working
This is a known issue with some of the Macbook Airs - you should bring the machine to an Apple store, or open a case at apple.com
They may be able to repair/replace at no cost, depending on how old the machine is.
Hope this helps, and good luck!
For audio expertise and great AA recordings come over to my website at www.rexark.com
SOURCE: How do you turn off DOS mode on a 13" MacBook Pro?
Is this a trick question? There is no "DOS mode" on a MacBook Pro.
Do you have WIndows installed as part of Boot Camp, and your machine is booting into Windows? To boot back into the Mac, either use the Boot Camp control panel in Windows, or hold down the Option key after you hear the startup chime and select the OS X partition to boot from.
