Open the front cover and push the lever that locks in the transfer belt and raises it carefully to remove it
Transfer kit is a sensitive and vital part of the printer. When it's worn out, it is advisable to replace it before continuing on printing.
Transfer kit if not replaced causes much more damage to the printer. Turn off and unplug the printer and let it cool down for a few minutes.
Open the front cover and push the lever that locks in the transfer belt and raises it carefully to remove it. Lift it gently on the side and slide it gently to completely remove.
Replace the transfer belt with the new one. Make sure to lock it safely before putting back the lid. Plug and turn on the printer
On the off chance if you are still getting troubles then call printer customer service number 1-888-597 3962 (Toll- free). Resource link: https://www.quickhelps.co/phone-number/epson/
SOURCE: Phaser 6100 - lever unlocking error
This printer is same as Samsung CLP-500. So the problem is the same: Contaminated transfer belt sensor.
Do as follow:
Lift transfer belt assy from printer(Drop down back door 90 degree, press white button, lift top cover and release 2 locking levers, grab handle, pull the belt unit out), turn upside down & rotate plastic roller until small clear "window" appears along one edge of belt. Clean both sides of clear window with cotton bud. on same side as window, remove 2 screws securing flimsy plastic cover to gain acess to sensor, (follow red/black wires)remove a screw and pull out "U" shaped sensor(light transmiter and receiver), cotton bud and blow away dust on slits on inner surfaces of sensor. Reassamble and everything should be ok.If not, senser may be too contaminated, clean slits vigorousley with cotton bud, or maybe you just need a new sensor.
The theory is that printer detect transfer belt by transmit light through the clear "window". If either window not clear or sensor is contaminated, light will not reach the receriver part of the sensor, printer will report such errors.
Good luck.
SOURCE: transfer belt errors
helped me and solved the lever and transfer belt. Actually it is the combined black toner cartridge and transfer belt. The side plate is about 3 inches long and has the two screws fixing it on. The sensor has a single screw fixing it, but in fact just looks like a black cover plate. Lever it out easilly at the screw end, not the other end which is impossible.
I just blew out the **** in the sensor, wiggled the white 3 pin connector, and since it has the look of a reflection based optical sensor, then I cleaned the belt along its edge with antistatic cleaner , ie tissue paper soaked and rotate the gear to move the belt round. There is a silver patch on the belt which passes the sensor once every revolution of the belt, and I gave this a particularly good clean as it is probably the only bit that matters.
Anyway, several black refills (hole and a bit of tape sealing it) later and the unit still works fine. Actually I always refill everything and just high pressure blow off the whole printer every so ofter.
SOURCE: 2 Errors
Transbelt is a part replacement-plain and simple. Samsung sucks for this, they give you no warning and just shut down the printer. www.samsungparts.com
SOURCE: "Lever Unlocking Error" Message
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
SOURCE: paper jammed at this time error message show on
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
