Question about Garden
John deer riding lawn mower the blade want engage when i pull up on the knob why? i check the fuses they are good what all i need to check?
I check the fuses they are good what all i need to check to fix the problem? when i pull up on the knob i do hear a noise sound like it on the deck but the blades want turn.
  • Garden Master
  • 1,183 Answers
With engine OFF and key in OFF position, check voltage at the battery posts with a digital multi meter (~$10 at any home improvement box store. It should read 12.5 VDC or greater. If not at least 12.5VDC, then battery/charging system failure. (The engine may start/run, but not enough power for the clutch.)
If battery voltage is 12.5VDC or greater, check for power at the clutch. With engine OFF and key in RUN postition, place the PTO switch in the ON position. You should hear a pop like sound from the clutch engaging. If no sound from clutch then there's an open circuit somewhere in the PTO power circuit or the clutch has failed. The clutch can be disconnected and powered by any 12V automotive battery (12.5VDC or greater).
If you want to trace the PTO clutch power circuit you will need make/model specific schematic.
Posted on Apr 01, 2019
    New Friend:
  • 18 Answers
Also a bad ground
    New Friend:
  • 7 Answers
Does it drive as normal? Does engine shut off when you pull the knob? If you have one with the reverse bypass that switch could be bad or wires are off. If it shuts off completely It could be the safety switch under the seat.
3 Suggested Answers
SOURCE:
  • 6468 Answers
SOURCE: John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
Posted on Apr 24, 2012
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
John deere d140 lawn mower shoots of when i ingage the blades
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE D140 SERVICE REPAIR MANUAL
May 04, 2017 | John Deere Garden
LX255 JOHN DEERE MOWER BLADES WILL NOT ENGAGE WHEN I PULL ON THE KNOB NEXT TO THE STEERING WHEEL.
Probably out of adjustment or the cable control, on some models, has stretched.
Sep 21, 2014 | Acer Aspire 5610-4648 Notebook
I need a diagram of a john deere L110 riding mower's blade engage
You go to searspartsdirect.com enter the model number and get the manual for any lawn mower
Jul 17, 2014 | John Deere Garden
Why mower blades will not engage when buttom is pulled
I believe this one has an electric clutch. Check to see that the switch is operating properly, that the wiring is good to the clutch, and that the clutch is good. Use a volt meter to check that there is voltage to the clutch when the switch is operated.
Jul 15, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Apr 23, 2012 | Garden
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
John Deer X475 lawn mower
Check fuses.Does the dash light for PTO come on?Right side screen by pedals sometimes comes in contact with wires and cuts them.This happens mainly on the older units.
Sep 19, 2009 | Garden
Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
49 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
