SOURCE: tanning bed setup
HI a bought a tanning bed last night from a tanning salon it was hooked threw a phone line or something like that my hubby brought it home and hooked it up here .now i cant get it to work ,will i ever see it work and how can i get it to work for me.
SOURCE: need a manual for esb 16 tanning bed free
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to factory installed systems not add
on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
SOURCE: Is tanning on a tanning bed just like tanning outside in the sun?
No - it's
very different as outside, various objects block the direct rays of the sun and
allow you to be outside in the sun for a lot longer. Tanning beds are very
instense. You should not be on the bed for longer than 10-12 minutes for your
first sessions and be very careful about adding extra time.
SOURCE: Are tanning beds safer than tanning in the sun?
Although
tanning beds are more controlled than tanning outside in the sun, ultimately
all exposure to UV rays is potentially dangerous to the skin and can put you at
risk of skin cancer and premature aging.
For a safer way of tanning - look for sunless tanning products rather
than using tanning beds or laying on the beach for hours.
Although tanning beds are more controlled than tanning outside in the sun, ultimately all exposure to UV rays is potentially dangerous to the skin and can put you at risk of skin cancer and premature aging. For a safer way of tanning - look for sunless tanning products rather than using tanning beds or laying on the beach for hours.
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
No - it's very different as outside, various objects block the direct rays of the sun and allow you to be outside in the sun for a lot longer. Tanning beds are very instense. You should not be on the bed for longer than 10-12 minutes for your first sessions and be very careful about adding extra time.
