This link has a lot of manuals. Try it
ManualsLib Makes it easy to find manuals online
SOURCE: Need Lowrey Organ Manual
Here you go. this is the web site that will fix you up.
http://www.lowrey.com/contact.aspx good luck DFD
please rate me TK U
SOURCE: User's manual for the Lowrey Organ Holiday Deluxe w/Magic Genie?
Here is a site to download manual:
http://www.lowreyforum.com/lowreymanuals.htm
A Leslie is special speaker system that is spun to break up the sound so it doesn't seem to come from a single point.
Sometimes the Leslie speaker is in a seperate cabinet fromthe organ, and SOMETIMES it is a simulated Leslie that is done with multiple speakers and electronic switching. If the Leslie is an external one, it usually attaches via a cable that often has either 9, 11, or 13 pins.
SOURCE: Have an older Lowrey organ with loud hum.
Of course it is repairable.
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
SOURCE: need a fuse for a lowrey-genie organ-44
My niece stuck a wire in my dads lowrey genie 98 organ now we get no sound.
could it be a blown fuse? Smells smokey when you now turn it on
SOURCE: What does a fuse look like for a Lowrey Teenie
well mr "poppa" im a tech and even i am confused. i got a 250v 1 amp fuse and they blew twice. noting else is wrong. so instead of being a smart ****, please enlighten this tech idiot as to what the fuse may look like? oh i know, its a cylender with wire inside. duh. now we need to know what voltage and amperage is needed in said cylinder. and naw duh electricity of that level can kill you. i forgot to put my tounge in the socket this morning. so please try to be less of a **** next time. as for the asker, i will try to research for you and every future tech who looks. once i find it i will give you a definite answer unlike the **** above me.
