Question about Samsung Televison & Video
I have a Samsung T.V. model# un58j5190afxza... Was watching T.V. one night and it just turns off by itself. Found the power supply board went out. Bought entire repair kit (t-con board,power board, wifi board, led strips and the other board) and replaced everything. Now I have standby light but no back light or picture or sound... Help!
SOURCE:
  • 257 Answers
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Posted on Aug 13, 2009
SOURCE: I got a Sony Bravia
http://www.smpcshop.com/KDL-40WL135-KDL-46WL135-p-8895.html
Above is a link for a service manual.
Hi, well I applaud you for starting in the right place, The power supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
Gee it seems that you have replaced just about the entire "Guts" of the set, in the industry we call this the "Shot gun" method, however it seldom works in reality. One really needs to isolate the Cause, of the "Fault" and repair that and also any damage done by that. As if one doesn't remove the "Cause" it will simply fault again when the "New" bit is connected up. One needs to get the unit going section by section, testing and proving the prior section before connecting up to the next, which also must be tested to make sure that what you are going to connect will NOT damage what you are connecting it to.
Also unfortunately, these LED's Blinks, are NOT an error code in actual fact.
What you need to do is use the service manual, and follow through the troubleshooting steps, to isolate and hopefully repair your problem.
Basically it is all about voltages and if they are correct, a Higher voltage than stated usually means a component is Open circuit or a very high resistance, whereas a Lower than stated voltage usually indicates a Short Circuit, or low value resistance component, is "Faulty". These are all in the SM, as are the waveforms that must be checked, it is indeed very difficult to repair electronics these days without specialised equipment and even though I have over 30 years experience i find it difficult, so good luck.
Posted on Feb 24, 2011
bronk50
  • 27725 Answers
SOURCE: powersupply went out replaced power supply on my DX4300 powers on but no picture on moniter
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Posted on Jun 19, 2012
vinceisaac
  • 2432 Answers
SOURCE: Samsung TV goes Black but keeps sound
you will need to check weather the 24vdc supply for the inverter board is good no drop voltage. if no supply check the power supply board. then you should check if their is a inv_on signal at the power inverter board around 3v-4.4vdc . if goes out during power on tried to disconnect the supply going to the inverter board to ensure if their is a shorted parts in the inverter board. if the inverter_on signal also goes out even with out inverter board connected that was mean you have problem in the processor board.
Posted on Nov 02, 2012
SD Tech
  • 14553 Answers
SOURCE: panasonic TC-42PX14 wont turn on power light flashes 1 time
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
Posted on Nov 05, 2012
Samsung went black while watching has sound no lights inside. Can see with menu with flash test
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
May 03, 2018 | Samsung Televison & Video
I have a samsung un39fh5000fxza the picture went dark while watching the other night ...I see no menu screen while doing the flashlight test and no lights thru the vents is it worth fixing & cost
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name and type of your device, in the search box [at the top right] of the display window; to gather down all the posts related to your device brand. It will make surf easy.
Jul 13, 2015 | Samsung Televison & Video
Hello, Last night my Samsung plasma TV made a fairly loud popping sound while I was watching it and then the power went off. When I turned back it on, no picture but sound was o.k.
Yes the caps on theower supply, but you can check power supply board by smell an look for burnt parts it is common. May need more than one board if they are cheap get both.
Jan 29, 2015 | Samsung Televison & Video
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
My Vizio LCD TV went out. Its just a black screen. The Vizio symbol turns on and off but no picture and no sound. It sounds like its similar to most peoples issues on here. How do I know if its my mai
There could be a few things that would cause this. I would suspect that you have a problem with either the power supply board or the main board. Based on my experience, the main boards go before the power supplies. What is the model #
Jan 26, 2013 | Vizio E550VA 55 in. LCD TV
Watching tv last night, the tv turn off by itself with out touching remote control, after that i keep trying to turn it on and the on/off red tv light startted flashing for a few minutes until it when off...
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Oct 07, 2010 | Samsung LN40A450 LCD TV
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
I have a Samsung LE40C530 lcd tv. I bought it on the 2nd June 2010. I was watching it last night when, all of a sudden, it turned itself off. Now there is no power on LED and no seemingly no power. There...
It is probably a bad power supply board and yes I have had to replace this board on new machines before. You need to call 1-800-samsung and set up a warranty service call.
Jul 01, 2010 | Televison & Video
Samsung ps42a456p2 (42 inch plasma) won't power on, stays standby
i'm pretty sure the power supply board is dead. the most common problem with all samsungs.
Oct 30, 2009 | Televison & Video
Televison & Video Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
