2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC?s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEMMITSUBISHI REAR PROJECTION
PTV SELF CHECK?2000-2001 ETC.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER
LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD ?device? and ?menu? buttons on front of tv
for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
IS IT 2 BLINKS AND PAUSE AND 3 BLINKS? this is error code indicating deflection circuit problem--some part shorted in the HV deflection circuitIS IT 2 BLINKS AND PAUSE AND 3 BLINKS? this is error code indicating deflection circuit problem--some part shorted in the HV deflection circuit
32 isnt a valid code for your model. Mitsubishi model WS55859 has only 5 possible codes they are 12, 21, 22, 23, and 24 Double check the code again and resond to this same post and i will assist you.
yes, two blinks then pause then 3 blinks
nope!
