AT&T Lucent MLS-12D Phone Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to turn the ringer off unless receiving a transfer.
I was wondering if there was a way that i could turn the ringer off on my phone with the exception of having a call transferred to me. I have a secretary that answers the phone so I don't see the need for my office phone ringing everytime we get a call unless it is for me.
Ryan Smith
Level 2:
  • Expert 62 Answers
  • Posted on Aug 06, 2009
Ryan Smith
Expert
Level 2:
Answers
62
Questions
0
Helped
20912
Points
187
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 28, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
735
Points
Additional information that will be helpful. Although Ryancsmith's answer explained how to fix the problem, he left out two steps getting there. In order to get to "system program" you need to push the left intercom button twice. Then to get to "Central tel program" you need to push the right intercom button twice. THEN you can proceed with Ryan's instructions. I'm sure those things are second nature to him, but to us idiot out here, we need our hand held all the way through. Thanks, Ryan for fixing my issue.
How do I turn off the ringer on an Inter-tel 662.3600?
Do Not Disturb --
While in do not disturb mode: You do not receive intercom calls, Transfered calls or pages, You do not receive direct ring in calls, Queue callbacks , and recalls.
* While on-hook, Press DND to turn on or to cancel. Key lights up when on and goes off when canceled. http://pdf.textfiles.com/manuals/TELECOM-F-R/Inter-Tel%20GX%20Keyset%202.pdf
Good morning. I have a panasonic kz-t7625 and the ringer volume is muted. I have tried turning up the volume and it still does not ring when we receive a call. I have checked the ringer buttons in the back...
This is a guess because I only have 4 7625's in my customer base, but in an idle 7630/33/36 phone, you can press the Navigator up or down button and the ringer volume will raise or lower. In the display phones, you actually can press it down 5 times and the ringer will turn off.
Give that a try (the up arrow part).
Carl
How do I turn off the ringer on my AT&T 832 telephone? I do not see a ringer button and I do not have a manual. The phone is about 12 years old.
Hi
You can turn off the ringer completely so it no longer makes an audible sound when the phone receives an incoming call. The phone's ringer options can be accessed in the handset's menu.
Press the "Menu" button on the phone.
Press the up or down arrows until the phone's display says "Ringer Volume."
Press the "Select" button on the phone.
Press the up or down arrows until the phone's display says "OFF."
Press the "Select" button to save your settings.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 14, 2011 • Cell Phones
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF
Please give me positive feedback if this helps you.
Thanks.
2helpful
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
1helpful
The ringer is turned off on my Cirrus 100 (onetel) telephone
I have the OT100 & to turn ringer off & on you press & hold down the * key until the phone beeps
I want to turn off "ringer mute" on my vtech 5.8 4-receiver system.
go to prog then press the up button next to dir then keep on going up in till you see 4 ringer when you see 4 ringer press select in tell you see but ues the up button
Ringer
go into profile and set ur message setting 2 silent and ur ringing tone 2 set anytone./.it wont make noise. reply me
Turn off ringer on an extension?
If you have a Strata CTX phone system you need to call your dealer unless you have the software program then I can help you.
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
